Ghost in a machine ?
  1. Oct 13, 2005 #1
    wolram
    Can there be such a thing ? at work there is a machine that constantly has
    breakdowns that defy logical explanation, human intervention has been ruled
    out as there are cameras in the room, and the only way the breakdowns could
    be man made is by some with tools and access to the machine
  3. Oct 13, 2005 #2
    Mk
    I think its the wol-RAM.
  4. Oct 13, 2005 #3
    wolram
    Ahhhh, no it is a problem i do not need :grumpy:
  5. Oct 13, 2005 #4
    Danger
    No.
    So what kind of machine, and what's going wrong? If things are loosening up, it's probably vibration-related. Likewise if settings are drifting.
  6. Oct 13, 2005 #5
    Math Is Hard
    Staff Emeritus
    There is a vending machine on campus that loves me. It gives me extra packages of chips and cookies.
  7. Oct 13, 2005 #6
    Danger
    Don't be fooled! It's only using you to get at your ipod.
  8. Oct 13, 2005 #7
    wolram
    Grrrr, that is naughty, but no this infernal machine some how jumps 1.5 toothed
    belts, that drive load free," other than a small amout of friction" comonents.
  9. Oct 13, 2005 #8
    It's called Windows :rofl:.
  10. Oct 13, 2005 #9
    wolram
    One up to motai :rofl: however our company is windows free, unless you count
    a laptop
  11. Oct 13, 2005 #10
    Danger
    So Wooley, are you referring to a 1 1/2 inch Gilmer drive? Does it have a tensioner? Also, unless the pulleys are rimmed, the slightest misalignment of the axles will cause the belt to 'walk off'. A worn bearing could be enough to do it.
  12. Oct 13, 2005 #11
  13. Oct 14, 2005 #12
    Math Is Hard
    Staff Emeritus
    oooh...Hypatia! I know how you can get rid of that demon-possessed Halloween novelty in your garage! And make a few bucks, maybe!
  14. Oct 14, 2005 #13
    wolram
    The same style as this only bigger.
    http://www.maplin.co.uk/Free_UK_Delivery/Timing_Pulleys_and_Belts_46676_v2.htm [Broken]
    And the guys who trade these drive systems and advise system design say no way can this happen.
  15. Oct 14, 2005 #14
    Lisa!
  16. Oct 14, 2005 #15
    wolram
  17. Oct 14, 2005 #16
    Lisa!
    :grumpy: :grumpy: Do you think money is more important than your health? I'm sure those ghosts don't like you and they may want to kill you. :rolleyes:
    And I guess your employer is with them or perhaps he's a ghost himself.
    Anyway it's others(:tongue2:) who should be worried about you not me. :wink:
  18. Oct 14, 2005 #17
    wolram
    I think you are looking for a job, what skills do you have ? i may be able to help
    :approve:
  19. Oct 14, 2005 #18
    Danger
    Okay, that's what I was thinking of. The flanges (what I called rims before) should prevent the belt from coming off. If by 'jumping' you just mean 'slipping', it shouldn't be possible unless it's way too loose. Once again I ask if there's a tensioner on it. If not, add one (or maybe even one on each side of the pulley) and see if it helps.
  20. Oct 14, 2005 #19
    wolram
    Sorry, yes there is a tensioner, one pully is driven via a 30mm shaft which
    connects to an 90 degree angle gear box 1:1 ratio, which in turn drives a
    simple rocking mechanism that picks a sleeve from a magazine and places
    it over a product, the sleeve is folded around the product down stream.
    both pullies have 8mm keys or maybe one is 6mm so they can not move on the
    shaft. we locked the mechanism up with a .5inch socket extension bar, the
    belt did not jump the main drive clutch operated first. :confused:
  21. Oct 14, 2005 #20
    Danger
    Sorry, but you're going to have to explain the last part of that in a lot more detail. Partly because I don't know where/what the clutch is, and partly because you sometimes use different terminology than I do, I can't follow what you mean. "locked the mechanism up"? And by "socket extension bar" do you mean one that goes between the ratchet and the socket for more reach, or a snipe for more torque?:confused: :confused: :confused:
