Gibbs Free Energy and Enthelpy
In summary, when studying chemistry in high school, one learns that if the change of enthalpy of a reaction ΔH > 0, the reaction is endothermic, and if ΔH<0, it is exothermic. However, in thermodynamic class, one learns that ΔG = ΔH - TΔS. For a reaction of a battery, the data reads ΔG = -394kJ/mol. The book then said that the difference (78kJ/mol.) comes from absorbing heat from the environment. So is this an endothermic reaction? However, ΔH<0. Is the system in fact absorbing heat or releasing heat?
Mayan Fung
131
When I studied chemistry in high school, I learned that if the change of enthalpy of a reaction ΔH > 0 , the reaction is endothermic, and if ΔH<0, it is exothermic.
However in thermodynamic class, I learnt:
$$ ΔG = ΔH - TΔS $$
ΔG = -394kJ/mol. (which is also the electrical work by the battery), ΔH = -316kJ/mol.
Thanks!
Science news on Phys.org
If the battery is maintained at constant temperature while it is doing the electrical work it will absorb that amount of heat from the environment and convert that heat to electrical work.
Can I say I can't determine whether the process is endothermic or not only by looking at the enthalpy?
Looking at the enthalpy change determines whether the reaction is exothermic or endothermic.
Um... but the system apparently is absorbing heat from the ambient?
Who says?
What book is this?
To get us started, rather than examining an electrolytic battery reaction, let's first start out simpler by considering a chemical reaction involving ideal gases. Please pick out an ideal gas reaction you would like to look, and look up the standard heats of formation and standard free energies of formation of the reactants and products at 25 C and 1 atm. We will use this to determine the standard heat of reaction and free energy of reaction, and will talk about how to carry out the reaction reversibly at 25 C and 1 atm.
Likes Bystander
It is from "An Introduction to Thermal Physics" by Daniel V. Schroeder. The following is a direct quote from the book:
$$ Pb + PbO_2 + 4H^+ + 2SO^{2-}_4 → 2PbSO_4 + 2H_2O $$
" ΔG for this reaction is -394kJ/mol, at standard pressure, temperature, and concentration of the solution. So the electrical work produced under these conditions, per mole of metallic lead, is 394kJ. Meanwhile, ΔH for this reaction is -316kJ/mol, so the energy that comes out of the chemicals is actually less than the work done, by 78kJ. This extra energy comes from heat, absorbed from the environment."
I can now see what your problem is. The change in enthalpy is equal to the amount of heat Q added only if the work involved in the process is P-V work at constant pressure. In a battery system, there is electrical work involved. So Q is not equal to ##\Delta H##. In this system, if the process is carried out reversibly, the amount of heat added is ##Q = T\Delta S##
Likes Mayan Fung and Bystander
Thanks for your explanation!
What is Gibbs Free Energy?
Gibbs Free Energy, also known as Gibbs energy or G, is a thermodynamic property that measures the amount of "useful" energy in a chemical or physical system. It takes into account both the internal energy of a system and the entropy (disorder) of the system.
What is Enthalpy?
Enthalpy, denoted by the symbol H, is a thermodynamic property that describes the total energy of a system. It includes the internal energy of the system as well as the system's pressure and volume.
How are Gibbs Free Energy and Enthalpy related?
Gibbs Free Energy and Enthalpy are both measures of the energy in a system, but they have different focuses. Enthalpy is concerned with the total energy of a system, while Gibbs Free Energy takes into account the energy that is available to do work. Enthalpy is related to Gibbs Free Energy through the equation G = H - TS, where T is the temperature and S is the entropy.
What is the significance of Gibbs Free Energy and Enthalpy in chemical reactions?
Gibbs Free Energy and Enthalpy are important in understanding chemical reactions and whether they are spontaneous or not. If the Gibbs Free Energy is negative, the reaction is spontaneous and can occur without outside energy input. If the Gibbs Free Energy is positive, the reaction is non-spontaneous and requires external energy input to occur. Enthalpy also plays a role in determining the spontaneity of a reaction, as it represents the total energy change in the system.
How do Gibbs Free Energy and Enthalpy relate to equilibrium?
In a closed system at constant temperature and pressure, a reaction will reach equilibrium when the Gibbs Free Energy is at its minimum. At equilibrium, the Gibbs Free Energy is equal to 0, indicating a balance between the energy available to do work and the disorder of the system. Enthalpy can also be used to predict the direction of a reaction at equilibrium, with reactions tending towards lower enthalpy (exothermic) as they reach equilibrium.
  • Thermodynamics
  • Thermodynamics
15K
10K
  • Biology and Chemistry Homework Help
