What Value Must n Be for a Glancing Elastic Collision to Occur?
In summary: I'm not sure what is wrong with it.The problem is that if you substitute n = 0 into v02 = nv12 + v22, you get v02 = v22. But from the diagram you see that v02 must be greater than v22. So n = 0 is not a solution.
Fizics14
1. Two masses, m and M are involved in a glacing collision as seen below where θ and ø= pi/2.
If M = nm what must n be such that the collision is elastic?
Remember if θ+ø=pi/2 then cos(θ)=sin(ø) and cos(ø)=sin(θ)
http://i934.photobucket.com/albums/ad181/Blake1090/5D07BDBF-C8CB-4A7F-BC36-1579FC060D6F_zpsmpdvbk61.jpg
2. I am suppose to find an number for n.
3. ∑KEo=∑KEf
1/2m[itex]_{1}[/itex]v[itex]^{2}_{0}[/itex]+0=1/2m[itex]_{1}[/itex]v[itex]^{2}_{f1}[/itex]+1/2m[itex]_{2}[/itex]v[itex]^{2}_{f2}[/itex]
substitute m[itex]_{1}[/itex]n for m[itex]_{2}[/itex] and cancel the 1/2m[itex]_{1}[/itex]
v[itex]^{2}_{o1}[/itex]=v[itex]^{2}_{f1}[/itex]+nv[itex]^{2}_{f2}[/itex]
n=[itex]\frac{v^{2}_{o1}-v^{2}_{f1}}{v^{2}_{f2}}[/itex]
Not sure what to do from here please help. I know I'm probably suppose to use the θ and ø, but I'm not sure how to incorporate it.
Known: M=nm, θ+ø=pi/2
Unknown: n
W[itex]_{NC}[/itex]=ΔKE+ΔPE
KE=[itex]\frac{1}{2}[/itex]mv[itex]^{2}[/itex]
Momentum=∑p=mv[itex]_{f}[/itex]-mv[itex]_{o}[/itex]
PS sorry I kinda messed this up it is my first post.
3. ∑KEo=∑KEf
Unknown: n
From conservation of energy:
mv02 = nmv12 + mv22
which can be rewritten:
(1) [itex]v_0^2 = nv_1^2 + v_2^2[/itex]
Now draw the vectors for the initial and final momenta of each body. What is the relationship between the initial total momentum and the final total momentum?
Since the final momentum vectors are at right angles to each other, what is the length of the sum of those two vectors (i.e. the magnitude of the final total momentum)? How is that length related to the length of the initial momentum vector?
Now compare that relationship with (1).
AM
The momentum should be equal since it is elastic so I'm assuming the vector before the collision should be equal to the vectors after the collision right? So I solved for two different equations. Separated them by x and y components. I'm not sure what to solve for now. I really need help I have to present this to the class on Monday!
while that method will work, it is easier to follow Andrew Mason's advice and draw the diagram representing the addition of the two vectors (the momenta of the two objects after collision). Every diagram representing the addition of two vectors is a triangle. For this problem that triangle turns out to be a square triangle which allows you to use Pythagoras theorem to relate the momenta of the particles before and after the collision.
How does finding that vector help me solve for n?
It will give you another equation. right now you have only one equation [itex]v^{2}_{o1}=v^{2}_{f1}+nv^{2}_{f2},[/itex] but that isn't enough because you don't know the speeds.
Okay so is this correct? Can you square both sides of that equation?
Here is my attempt and now I'm stuck...
You're almost there. Your triangle looks right, but you labeled it with speeds v. speed isn't a conserved quantity. you should've labeled the triangle with momenta p where p = mv. Momentum is a conserved quantity.
When I change it to momentum I think it just solves for the equation we already have right?
By the way thank you so much for helping! I'm sorry I'm so bad at this :/
No, not right. You get a different equation. Do it.
My attempt:
Yes, that's the equation. Now, what can be canceled out of that equation at the bottom of the page?
Fizics14 said:
My attempt:
Ok. So what value of n satisfies that relationship:
[itex]v_{f1}^2 + (nv_{f2})^2 = (v_{f1}^2 + nv_{f2}^2)[/itex]
AM
Is it just 1?
ding ding ding!
Sweet haha thanks you guys so much!
Fizics14 said:
Is it just 1?
Very good. Is that a guess? Work it out algebraically to show that n = 1 and then we will give you full marks.
AM
There is another solution. Can you see it?
I'm guessing zero so I should probably put both
Yes, it is zero, but don't guess it. Find it algebraically. Even though zero is a solution, there is something wrong with it. Can you tell what it is?
Yes I did find it algebraically, but there is something wrong because then the mass would just be zero which can't be true.
Well there are particles that are truly massless such as the photon but they are governed by relativistic formulae which are different than the ones you used, so you would have to redo your calculations. Alternatively you might say that the particle really isn't massless but has a negligible mass, in which case the angle really isn't 90 degrees, but it is close.
I was thinking of a point particle with infinitesimal mass like that but I don't think that's what the problem is about. Thank you! I'll be back no doubt!
How does n=0 satisfy:
[itex]v_{f1}^2 + nv_{f2}^2 = v_{f1}^2 + v_{f2}^2[/itex]?
If n is very small it does not begin to satisfy the relationship. I think n=1 is the only solution.
By the way, billiards players know that the angle between the cue ball and object ball is 90° (absent spin on the cue ball).
AM
AM
that's not the equation I got. My solution looks like
[itex]v_{f1}^2 + nv_{f2}^2 = v_{f1}^2 + n^2v_{f2}^2[/itex]
Ok. Same thing. There is really a discontinuity at n=0. For any n in an arbitrarily small neighbourhood of 0, n does not come close to satisfying the equation.
The condition that the bodies recoil at 90° to each other is not met using classical mechanics if the mass of the second particle (the one initially at rest) is zero.
AM
What is a Glancing Elastic Collision?
A Glancing Elastic Collision is a type of collision between two objects where both the kinetic energy and the momentum are conserved. This means that after the collision, the objects involved will continue to move at the same speeds and directions as before the collision, but may change their directions.
What are the factors that affect a Glancing Elastic Collision?
The factors that affect a Glancing Elastic Collision include the mass and velocity of the objects involved, as well as the angle at which they collide. The elasticity of the objects, or their ability to deform and recover their original shape, also plays a role in the collision.
How is a Glancing Elastic Collision different from other types of collisions?
A Glancing Elastic Collision is different from other types of collisions, such as inelastic collisions, because the objects involved do not stick together after the collision, and their kinetic energy and momentum are both conserved. In inelastic collisions, the objects may stick together and their kinetic energy is not conserved.
What is the equation for calculating the final velocities in a Glancing Elastic Collision?
The equation for calculating the final velocities in a Glancing Elastic Collision is vf1 = [(m1 - m2)/(m1 + m2)] * v1i + [(2*m2)/(m1 + m2)] * v2i and vf2 = [(2*m1)/(m1 + m2)] * v1i + [(m2 - m1)/(m1 + m2)] * v2i. In this equation, vf1 and vf2 are the final velocities of the two objects, m1 and m2 are their masses, and v1i and v2i are their initial velocities.
What are some real-life examples of Glancing Elastic Collisions?
Some real-life examples of Glancing Elastic Collisions include billiard balls colliding on a pool table, balls colliding on a billiards table, and two vehicles colliding at an angle. These collisions can also be seen in sports such as soccer, where players collide at an angle while trying to steal the ball from each other.
