Gnuplot matrix plot
I have a .txt file which is 50 rows x 50 columns filled with entirely 0's and 1's.
I have tried to plot the data with and without spaces between each column.
I keep getting this message:
gnuplot> splot 'C:\Users\raf\Desktop\PolymerProject\monte carlo code\directionInitial.txt' with pm3d
warning: Skipping unreadable file "C:\Users\raf\Desktop\PolymerProject\monte carlo code\directionInitial.txt"
warning: No usable data in this plot to auto-scale axis range
All points x value undefined
None of the advice online seems help/solve my problem. New to gnuplot so excuse me if this is obvious.
Answers and Replies
Please post your code. Attaching your text file might be helpful, as well.
This what I enter into the command box:
gnuplot> set pm3d map
gnuplot> splot 'C:\Users\raf\Desktop\PolymerProject\monteCarloCode\directionInitial.txt'
As I said I've tried various different spacings in the .txt file.
  • directionInitial.txt
Just as I read my post back I realized I have entered the incorrect path file.
I found this documentation -- http://theochem.ki.ku.dk/on_line_docs/gnuplot/gnuplot_36.html
Your data file doesn't seem to match the format used in this example.
A simple example of plotting a 3-d data file is
splot 'datafile.dat'
where the file "datafile.dat" might contain:
# The valley of the Gnu.
0 0 10
0 1 10
0 2 10
1 0 10
1 1 5
1 2 10
2 0 10
2 1 1
2 2 10
3 0 10
3 1 0
3 2 10
Note that "datafile.dat" defines a 4 by 3 grid ( 4 rows of 3 points each ). Rows (datablocks) are separated by blank records.
Note also that the x value is held constant within each dataline. If you instead keep y constant, and plot with hidden-line removal enabled, you will find that the surface is drawn 'inside-out'.
Actually for grid data it is not necessary to keep the x values constant within a datablock, nor is it necessary to keep the same sequence of y values. gnuplot requires only that the number of points be the same for each datablock. However since the surface mesh, from which contours are derived, connects sequentially corresponding points, the effect of an irregular grid on a surface plot is unpredictable and should be examined on a case-by-case basis.
Suggested for: Gnuplot matrix plot
