Going below 0° Kelvin
  • Thread starter Glynis
Main Question or Discussion Point
As there is nowhere in the Universe below 0° Kelvin. Could heat be considered a universal inconsistent medium?
If we were to go below 0° Kelvin, would total inertia follow?
Thanks,
Glynis
Answers and Replies
as there is no activity of atoms and molecules at that temperature,no movement no heat.
EL
You can, however, get negative Kelvin values - follow up the link in the Wiki article.
Mm, I saw that, but didn't want to confuse...
Gokul43201
Staff Emeritus
What in the heavens is a "universal inconsistent medium"?
"Total inertia"? What's that?
russ_watters
Mentor
19,705
6,047
As there is nowhere in the Universe below 0° Kelvin. Could heat be considered a universal inconsistent medium? If we were to go below 0° Kelvin, would total inertia follow?
Thanks,
Glynis
I'm sorry, but you've put a bunch of words together that doen't belong in the same sentences with each other. So I guess that means the answer to your questions is no.
disregardthat
33
What about adding heat to a object moving almost at light speed. when the atoms are moving back and forth in their extreme heat, wouldnt it make the speed of the atoms exceed the speed of light when they move towards the direction of the object? of an atom moves at a speed of 50 000 km\s back and forth very fast. and an object is moving 270 000 km\s it would be 320 000 km\s? (Data is totally imaginary)
Gokul43201
Staff Emeritus
No, it wouldn't. That's not the correct way to add velocities.
As Gokul said, and the reason is because you haven't considered the structure of geometry in which the atoms are contained in. This geometry is spacetime and all matter constains in it hence they must also obey its rules.
disregardthat
33
Hmmm what rules are these then?
The atoms at great speeds vibrate "slower" compared to a object standing still so they will always move just below the limit of c?
ShawnD
Not to crap on the thread but this is the coolest quote ever. Should I make this my new signature or is thunderfvck's quote better? :biggrin:
Thanks,
Glynis
Beware of what you say here.
T < O K IS POSSIBLE....But then again, such fenomena are very exotic. For example in some spin-systems (i mean many atoms and we only look at spin spin interactions) absolute NEGATIVE temperatures can arise. These temperatures are no really negative, but they need to be looked at as bigger then infinity....
The conditions for this to occur are for example that the spin-spin relaxation time is little compared to the spin lattice relaxation time. This means that the spins mutually interact long before thermal degrees of freedom come into play. KEEP IN MIND THAT WE ARE NOT TALKING ABOUT THERMAL DEGREES OF FREEDOM HERE !!!
regards
marlon
Mk
1,984
I completely do not understand negative temperature. Can someone explain it to me?
disregardthat
33
Here's a good explanation: It does not exist, at least not in common sense.
russ_watters
Mentor
19,705
6,047
If you do, please fix the grammar - "sentences" should be singular. :grumpy:
... total inertia follow?
Would this be similar to total hypothermia? :confused:
isn't it-theoreticaly- impossible to get to 0 K anywhere in the universe? I know we have gotten pretty close to 0K with liquid He and partical KE is reduced with some odd observations>
I am not sure if it is impossible to get to 0 K but I know it is impossible to measure 0 K because the act of measurement will intefere with the system and raise its temperture in one way or another.
disregardthat
33
How ironic! It is at least extremely hard to achieve 0 K, because we are always surrounded by energy at all times. At least that's what i think the reason is.
Nobody has answered this yet...
a medium that is not consistant through out the universe maybe?
If in an isolated experiment someone reached 0 degrees Kelvin would there then be a chain reaction leading to total inertia, i.e. the death of the universe?
Hmm... well, heat is associated with chaotic disordered behavior, and is often a waste product or conversion penalty when other forms of energy convert to each other.
So I guess it is the universal "currency"/"expression" of chaos or randomness.
Can we call it a medium?
I thought the medium is something that would carry the heat/chaos/randomness. So should we call heat a "universal state of inconsistency" or "universal form of chaos"?
Even then, we have to say "a" and not "the", since you could say that the turbulence of the dynamic vacuum is yet another layer of chaos below that of heat.
By a medium I mean being present to a greater or lesser degree, throughout the universe. I.e. that heat molecules must be present everywhere, even within a vacuum, as there must be some degree of heat throughout the universe.
Related Threads on Going below 0° Kelvin
  • Last Post
11K
  • Last Post
  • Last Post
  • Last Post
10K
13K
