Golf Ball Projectile Motion Problem -- Solved
In summary, the conversation discusses finding the range using the given values of initial velocity (v0), angle (θ), and acceleration due to gravity (g). The correct equation for finding range is (2v0*cosθ * (v0sinθ)/g) and after correcting for units, the correct answer is 69.02. The discrepancy in the calculation is due to an error in using the calculator.
Undeterred247
After a golf ball is hit it takes off with an initial speed of 26.6 m/s and at an angle of 36.5° with respect to the horizontal. The golf field is flat and horizontal. A) Neglecting air resistance how far will the golf ball fly? B) How high will the golf ball rise? C) How much time will the ball spend in the air? D) How far would the ball fly if the initial speed was doubled? E) How much time would the ball spend in the air in this second case? Thanks
Range = 2v0*cosθ * (v0sinθ)/g = (v0^2)/g *sin2θ
26.6m/s = v0
36.5º = θ
g = 9.81m/s^2
A) Find Range:
(v0^2)/g *sin2θ = (26.6^2)/9.81 * sin2(36.5)
= 89.99
I double-checked with the other Range equation (2v0*cosθ * (v0sinθ)/g) so I know I'm doing something wrong. Please help! Thank you
edit: A) Correct answer is 69.0
Undeterred247 said:
26.6m/s = v0
36.5º = θ
g = 9.81m/s^2
Find Range:
= 89.99
(v0^2)/g *sin2θ = (26.6^2)/9.81 * sin2(36.5) is not 89.99 unless the units are not meters but something else. What you are doing wrong is between you and your calculator.
Likes Delta2
Oh my- Thank you!
Likes berkeman
What is the Golf Ball Projectile Motion Problem?
The Golf Ball Projectile Motion Problem refers to the study of the trajectory of a golf ball when it is hit by a club. It involves understanding the forces acting on the ball and how they affect its motion.
What factors affect the trajectory of a golf ball?
The trajectory of a golf ball is affected by various factors such as the initial velocity, angle of launch, air resistance, and gravity. These factors can be manipulated to control the distance and direction of the ball's flight.
How is the Golf Ball Projectile Motion Problem solved?
The Golf Ball Projectile Motion Problem is solved using mathematical equations and principles of physics. By considering the forces acting on the ball and using formulas such as Newton's laws of motion and the equations of projectile motion, the trajectory of the ball can be calculated.
What is the importance of understanding the Golf Ball Projectile Motion Problem?
Understanding the Golf Ball Projectile Motion Problem is important for golfers to improve their game. By knowing the factors that affect the ball's trajectory, they can adjust their swing and aim to achieve their desired shot. It also has practical applications in engineering and sports technology.
What are some real-world examples of the Golf Ball Projectile Motion Problem?
The Golf Ball Projectile Motion Problem can be seen in various sports such as golf, baseball, and tennis. It is also relevant in the design of ballistic missiles and projectiles used in military operations. Additionally, it is studied in physics classrooms as an example of projectile motion.
