What is the minimum energy required to escape a gravitational field?
In summary, the author is discussing how to calculate the gravitational potential energy between two objects. The author mentions that the U = 0 reference configuration is convenient, and that when two objects are separated by an infinite distance, the initial potential energy is zero. The author then discusses how to calculate the energy needed to separate two masses, without worrying about the details of the gravitational potential energy.
Bashyboy
1,421
Hello,
I am currently reading about the conception of a general expression for gravitational potential energy. I understand that we have to use methods of calculus to generate a general expression of gravitational potential energy, because when considering alterations to the configuration of an object in a gravitational field that are large, the force varies. The force is varying as it is being applied over a distance to counter the gravitational force it is experiencing from another object. What I am getting confused over is this part of the derivation:
[itex]U_f-U_i = -GM_Em(\frac{1}{r_f}-\frac{1}{r_i})[/itex]
The paragraph accompanying this fuction:
"As always, the choice of a reference configuration for the potential energy is completely arbitrary. It is customary to choose the reference configuration for zero potential energy to be the same as that for which the force is zero. Taking [itex]U_i=0[/itex] at [itex]r_i= \infty[/itex], we obtain the important result,
[itex]U(r)=-\frac{GM_Em}{r}[/itex]"
Th portion in red I don't quite understand. Is that saying when the two bodies in question are separated by an infinite distance, the initial potential energy is zero? What is that suppose to mean, and why does it allow us to do away with the [itex]U_i[/itex] term?
Also, in my textbook it says, "When two particles are at rest and separated by a distance r, an external agent has to supply an energy at least equal to [itex]+Gm1m2/r[/itex]to separate the particles to an infinite distance." I know that if I wanted to separate, say, the moon and earth, which as a system possesses gravitational energy, that I would need to apply a force on the moon. Moreover, I would have to be applying this force over a distance, meaning I am putting energy into the moon. But how am I suppose to know that the equal that I provide by applying a force over a distance to free the moon from Earth's gravitational pull is exactly [itex]+Gm1m2/r[/itex]? Honestly, if someone was in the enterprise of moving the moon, they'd be more concerned with the force that Earth pulls on the moon, so that they could counter it and move the moon, and not with the gravitational potential energy of the moon. Again, this infinite distance business comes up, what exactly do they mean by this?
Finally, I am also reading about Energy Considerations in Planetary and Satellite Motion. The mechanical energy equation the derive, of which I understand, is [itex]E = 1/mv^2 - \frac{GMm}{r}[/itex], where we don't consider the kinetic energy of the object the satellite is rotating around. One thing the author says in my textbook is, "...[itex]E[/itex] may be positive, negative, or zero, depending on the value of [itex]v[/itex]." Could someone give scenarios that would correspond to those possibilities, that [itex]E[/itex] is positive, negative, zero?
I would appreciate the help. Thank you in advance!
As the first sentence in the quoted paragraph reminds you, the choice of U = 0 is arbitrary. But it's very convenient to choose such a reference (U = 0 when r = ∞) as it simplifies any calculations.
The power of energy considerations is that you can answer the question of how much energy is needed to separate two masses without worrying about the details of the force involved.
If the total energy is negative, the bodies are bound together. (The satellite cannot escape.) If the satellite has too much energy (it has a speed greater than the so-called escape velocity), the 'orbit' is free. The satellite will just keep going (assuming it's not on a collision course).
Do a search on "orbits" and you'll find various classifications.
Right.
The first formula does not fix the potential to a unique value - you could use any initial position you like to define the potential.
In a lab, it is conventional to define the floor as "0 potential energy here". But if you do not have a floor, how do you define a unique potential? The easiest way is "0 potential energy is at infinite distance".
This is constant - and in classical physics, you do not have to care about absolute energy. Only energy differences matter, and they remain the same if you remove a constant term.
This is a direct result for the formula above. The motion of the moon is ignored here.
But that is the same!
Well, in our universe, objects cannot have an infinite distance. But you can get quite close - if you move moon to 1000 times its current distance from earth, you have to provide 99,9% of the energy needed to move it "to infinity" (or "arbitrarily far").
This should be 1/2mv^2, I think you just forgot the 2.
It is negative for everything orbiting another object, e.g. the moon. It is positive for objects so quick that they leave the other object permanently, for example the Voyager probes, leaving the solar system. It is zero for objects directly in between.
Okay, I believe all of my questions have been sufficiently answer. Except, however, how do I know that [itex]+Gm_1m_2/r[/itex] is the minimum amount of energy I need to provide an object in orbit, in order that it may leave its orbit?
The quote you posted actually says objects at rest, not in orbit. That changes the answer. The point is that the total energy needs to be at least 0 for the object to escape (again using the convention where the potential is zero at infinity). If it is at rest, the total energy is [itex]-\frac{Gm_1m_2}{r}[/itex] and therefore you need to supply at least [itex]\frac{Gm_1m_2}{r}[/itex] to get it to 0. If it is in orbit, it has some kinetic energy and the minimum energy will be different.
1. What is GPE?
GPE stands for gravitational potential energy, which is the energy an object possesses due to its position in a gravitational field. It is directly related to an object's mass and height above the ground.
2. How is GPE calculated?
The formula for calculating GPE is GPE = mgh, where m is the mass of the object, g is the acceleration due to gravity, and h is the height above the ground. This formula assumes a constant gravitational field and neglects any other factors such as air resistance.
3. What is ME?
ME stands for mechanical energy, which is the sum of an object's kinetic energy and potential energy. It is a measure of an object's ability to do work.
4. How is ME related to GPE?
ME is related to GPE in that GPE is a type of potential energy that contributes to an object's overall mechanical energy. As an object falls, its GPE decreases while its kinetic energy increases, resulting in a constant ME.
5. What is binding energy?
Binding energy is the energy required to separate a system of particles into individual components. In physics, it is often used to describe the energy that holds an atomic nucleus together, which is known as nuclear binding energy.
  • Other Physics Topics
  • Classical Physics
  • Classical Physics
