- 10,776
- 3,635
In a thread that is now closed in the QM sub-forum someone wrote:
Isn't spacetime supposed to be fixed, "it just is", not changing or evolving?
To which I replied:
These days we know the core of GR - its simply this - no prior geometry (it's dynamical) which is the exact opposite of the above.
But Peter Donis, who I know knows GR well posted:
I gave his answer my like because its an opportunity to fix a possible misconception I have, but for me what I said is what I thought no prior geometry meant and that geometry itself is dynamical - ie has its own Lagrangian.
I pulled out my copy of Wald and went to appendix E page 453 where the simplest possible Lagrangian embodying that, Lg = √-g R is given. Of course the full Lagrangian contains matter and fields with Lagrangian Lm so you get the total Lagrangian
L = Lm + √-g R
R is the curvature scalar and is the simplest scalar you can write embodying the curvature - its very elegant for it to be the Lagrangian. I don't know what to call it other than no-prior geometry - its seems a common name for the idea from a number of texts eg MTW uses it:
https://physics.stackexchange.com/q...o-prior-geometry-father-50-years-of-confusion
We know Einstein was wrong when he used General Covarience as the basis as pointed out by Kretschmann. Instead it became the principle of general invariance - something slightly different - but still that there is no set background geometry is the key.
You take the variation and you end up with the EFE's - the variation of Lm is defined as the stress energy tensor.
At one time I was heavily into GR - but it was a while ago. Where have I gone wrong? Was it my wording? What would be better wording if that's the case?
Thanks
Bill
To which I replied:
PeterDonis said:No, it isn't. "No prior geometry" means the geometry depends on the distribution of stress-energy, via the Einstein Field Equation; there is no fixed geometry built into the laws of physics, the way there is in SR. It doesn't mean that the geometry "changes"; any given solution of the Einstein Field Equation describes a geometry, period; it doesn't describe one geometry "changing" into another.
L = Lm + √-g R
Thanks
Bill
