Understanding Gradient and Curl: Equations and Directions
In summary, the gradient of a function in a given point represents the direction of the fastest change of the function. Similarly, the curl of the function in a point represents the axis about which a sphere would spin if it were fixed in place and torqued by the function. This concept works in 3D as a disguised bivector, and in general, the plane of the bivector curl would be the plane of rotation for the fixed sphere. In higher dimensions, there could be multiple planes of rotation. As for the second question, the equation for the curl of the function in a given direction is given by ∇×f·n, where n is the fixed axis.
Jhenrique
685
If the direction of the gradient of f in a point P is the direction of most/minor gradient, so a direction of the curl of f in a point P is the direction of most/minor curl too, correct?
Also, if the gradient of f in the direction t is given by equation: t, so the curl of f in the direction n is given by equation: ×f·n, correct?
I don't understand what you mean by "minor".
The direction of the gradient is the direction where [itex]f[/itex] changes the fastest.
I believe the direction of the curl is the axis about which a sphere would spin, if it were fixed in place and torqued by [itex]\vec{f}[/itex].
Of course, the "vector" "curl" only works in 3D; it's really just a disguised bivector, which works in any 2+-dimensional space. So in general, the plane of the (bivector) curl would be the plane of rotation for that fixed sphere.
Interestingly, in 4+ dimensions, there could be multiple such planes simultaneously!
As to your second question, I believe you're correct: [itex](\nabla \times \vec{f}) \cdot \vec{n}[/itex] gives the amount of rotation for a fixed axis (fixed along [itex]\vec{n}[/itex]).
1. What is a gradient?
A gradient is a mathematical concept that describes the rate of change of a function in a particular direction. It is represented by a vector that points in the direction of the steepest increase of the function.
2. How is the gradient calculated?
The gradient is calculated using partial derivatives of a multi-variable function. Each component of the gradient vector is equal to the partial derivative of the function with respect to that variable.
3. What is the physical interpretation of the gradient?
The gradient can be thought of as a slope or a steepness in a particular direction. In physics, it represents the direction and magnitude of the maximum rate of change of a physical quantity, such as temperature or pressure.
4. What is the curl?
The curl is another mathematical concept that describes the rotation or circulation of a vector field. It is represented by a vector that points in the axis of rotation and its magnitude is equal to the amount of rotation.
5. How is the curl calculated?
The curl is calculated using the partial derivatives of the vector field with respect to each variable. It involves calculating the determinant of a matrix formed by the partial derivatives and taking the cross product with the unit vector in the direction of rotation.
  • Differential Geometry
  • Electromagnetism
  • General Math
  • General Math
