erisedk
- 374
- 7
How many moles is 0.01 gram formula weight of NaCN?
I thought it meant 0.01/49 moles of NaCN.
The solution simply says 0.01 moles. Why?
What's the definition of 1 mole of a particular substance? How is it calculated?erisedk said:Homework Statement
How many moles is 0.01 gram formula weight of NaCN?Homework Equations
erisedk said:gram formula weight
To calculate the moles of NaCN, you need to divide the given mass of NaCN by its gram formula weight (molar mass). The gram formula weight of NaCN can be found by adding the atomic weights of the individual elements in the compound (Na = 22.99 g/mol, C = 12.01 g/mol, N = 14.01 g/mol). So, the formula would be: moles of NaCN = mass of NaCN (g) / gram formula weight of NaCN (g/mol).
The gram formula weight of NaCN is 49.01 g/mol. This can be calculated by adding the atomic weights of sodium (22.99 g/mol), carbon (12.01 g/mol), and nitrogen (14.01 g/mol).
To determine the mass of NaCN from a given number of moles, you need to multiply the number of moles by the gram formula weight of NaCN. So, the formula would be: mass of NaCN (g) = moles of NaCN × gram formula weight of NaCN (g/mol).
No, you cannot calculate the moles of NaCN without knowing the gram formula weight. The gram formula weight is a crucial factor in determining the number of moles in a given mass of a compound.
No, the gram formula weight is specific to a particular compound and cannot be used to calculate the moles of other compounds. Each compound has its own unique gram formula weight, which is determined by the individual atomic weights of the elements present in the compound.
