Gram-Schmidt Procedure
  1. Oct 19, 2009 #1
    We consider P2 the vector space of all real polynomials of degree at most 2.
    <f,g> = [itex]f(-1)g(-1)+f(0)g(0)+f(1)g(1)[/itex]
    Use the Gram-Schmidt procedure to construct an orthonormal basis for P2 from the basis {1,t,t2}
    2. Relevant equations
    [itex]
    v_{j+1}:=u_{j+1}-\sum_{i=1}^{j}<<u_{j+1},e_{i}>>e_{i}[/itex]
    [itex]
    e_1 = \frac{u_1}{||u_{1}|| }[/itex]
    3. The attempt at a solution
    I have a basis [itex] u_1 = 1, u_2 = t, u_3 = t^2[/itex]
    so
    [itex]
    [itex]
    e_1 = \frac{1}{\sqrt{2}} [/itex]
    is the next step
    [itex]
    v_{2}:=u_{2}-\sum_{i=1}^{j}<<u_{2},e_{i}>>e_{i}[/itex]
    [itex]= t - << t,\frac{1}{\sqrt{2}} >>\frac{1}{\sqrt{2}}[/itex]
    My question is how do I calculate the inner product [itex]<< t,\frac{1}{\sqrt{2}} >>[/itex]
    do I need to plug in the value of f(t) into
    and does g() become [itex]
    g(e_1) = g(\frac{1}{\sqrt{2}}) [/itex]
    regards
  3. Oct 19, 2009 #2
    Dick
    The inner product <<t,1/sqrt(2)>>=(-1)/sqrt(2)+0/sqrt(2)+(1)/sqrt(2). That's what you definition says, isn't it? g is a constant.
  4. Oct 20, 2009 #3
    So
    [itex]v_{2}:=u_{2}-\sum_{i=1}^{j}<u_{j+1},e_{i}>e_{i}[/itex]
    [itex]= t - (\frac{-1}{\sqrt(2)}+\frac{0}{\sqrt(2)}+\frac{1}{\sqrt(2)}) \frac{1}{\sqrt{2}}[/itex]
    [itex]= t - (0) \frac{1}{\sqrt{2}}[/itex]
    [itex]v_{2}:= t[/itex]
    for v3: do I substitute [itex]v_{2}:= t[/itex] from above for [itex]e_{2}[/itex]
    in the next equation? or do I need to nomalise it first
    [itex]v_{3}:=u_{3}-\sum_{i=1}^{j}<u_{j+1},e_{i}>e_{i}[/itex]
    [itex]= t^2 - (<< t^2,e_{2} >>e_{2}) + (<< t,\frac{1}{\sqrt{2}} >>\frac{1}{\sqrt{2}})[/itex]
    [itex]= t^2 - (<< t^2,t >>t) + (<< t,\frac{1}{\sqrt{2}} >>\frac{1}{\sqrt{2}})[/itex]
    or
    [itex]= t^2 - (<< t^2,1 >>1) + (<< t,\frac{1}{\sqrt{2}} >>\frac{1}{\sqrt{2}})[/itex]
    regards
  5. Oct 20, 2009 #4
    That last equation was using [itex](\frac{1}{t})t= 1[/itex]
    as [itex]e_{2}[/itex]
  6. Oct 20, 2009 #5
    Dick
    t is orthogonal to e1=1/sqrt(2) (i.e. <t,1/sqrt(2)>=0). But it's not normalized. <t,t> is not one. Normalize it. Then that becomes e2. Then find u3=t^2-(<t^2,e1>e1+<t^2,e2>e2) and normalize u3. Your are getting your functions all mixed up in the Gram-Schmidt process.
  7. Oct 20, 2009 #6
    Dick
    BTW before you go any further <1,1>=3. So the normalization of 1 isn't 1/sqrt(2). It's 1/sqrt(3). Sorry, I missed that.
  8. Oct 20, 2009 #7
    Thanks
    So
    therefore
    [itex]e_{2} = \frac{t}{||v_2|| }v_2[/itex]
    [itex]e_{2} = \frac{t}{\sqrt{-1^2+0^2+1^2}}[/itex]
    [itex]e_{2} =\frac{1}{\sqrt{2}}[/itex]
    is that right ?
  9. Oct 20, 2009 #8
    Dick
    Is boneill3 the same person as beetle2? If so the Forum doesn't allow really allow you to use two different user pseudonyms. If you are, please stick with one, ok? Otherwise I should report this. If you aren't you are doing exactly the same kind of notational confusion as boneill3. If v2=t, then e2=v2/||v2||=t/||t|| which is t/sqrt(2). Not 1/sqrt(2).
  10. Oct 20, 2009 #9
    Hi,
    Sorry I had to log in from another computer.
    I found u3=t^2-(<t^2,e1>e1+<t^2,e2>e2) to equal
    t^2-(1/sqrt(3)(1/sqrt(3)+1/sqrt(3)) + t/sqrt(2) (t/sqrt(2)+ t/sqrt(2))
    = t^2 - (2/3+t^2)
    u3 = -2/3
    does normalising make it e3= -(2/3) / sqrt((-2/3)^2 +(-2/3)^2+(-2/3)^2)
    e3 = -1/sqrt(3)
  11. Oct 21, 2009 #10
    I think i'll make it clearer
    I found
    [itex]u3=t^2-(<t^2,e_1>e_1+<t^2,e_2>e_2) [/itex]
    to equal
    [itex]t^2-(\frac{1}{\sqrt{3}})(\frac{1}{\sqrt{3}}+\frac{1}{\sqrt{3}}) + (\frac{t}{\sqrt{2}}) (\frac{t}{\sqrt{2}}+\frac{t}{\sqrt{2}})
    = t^2 - (\frac{2}{3}+t^2)
    = \frac{-2}{3} [/itex]
    [itex]e_{3}= \frac{\frac{-2}{3}}{{\sqrt{(\frac{-2}{3})^2 +(\frac{-2}{3})^2+(\frac{-2}{3})^2}}}[/itex]
    [itex]e_{3} = \frac{-1}{\sqrt{3}}[/itex]
  12. Oct 21, 2009 #11
    Dick
    If that whole thing had worked then you should be able to check that <e1,e3>=0. It's not zero. The inner product of two functions of t, <f(t),g(t)>, should always be a number, not another function of t. Try computing <t^2,t/sqrt(2)> again.
  13. Oct 21, 2009 #12
    So,
    to compute <t^2,t/sqrt(2)>
    we have
    [itex]\left[(-1)^2(\frac{-1}{\sqrt{2}})+](0)^2(\frac{0}{\sqrt{2}})+](1)^2(\frac{1}{\sqrt{2}})\right][/itex]
    therfore
    [itex]t^2-(\frac{1}{\sqrt{3}})(\frac{1}{\sqrt{3}}+\frac{1}{\sqrt{3}}) + (\frac{t}{\sqrt{2}}) (0)
    = t^2 - (\frac{2}{3}) [/itex]
  14. Oct 21, 2009 #13
    Dick
    Ok, now you just have to normalize t^2-(2/3).
  15. Oct 21, 2009 #14
    I normalised u3 and got
    [itex]e_{3}= \frac{t^2-\frac{-2}{3}}{\sqrt{\frac{2}{3}}}[/itex]
    I checked that <e1,e3>=0 which it does.
    Thanks so much for your help
Similar Discussions: Gram-Schmidt Procedure
  1. Gram-Schmidt process (Replies: 10)
  2. Gram Schmidt question (Replies: 6)
  3. Gram-Schmidt Process (Replies: 2)
Loading...
