Graph + Algebra Question
  1. Sep 15, 2007 #1
    Hello, I am a 14 year old boy doing my GCSE's for Maths. And I was doing some past papers and I came across this question which I have never seen before. I looked in textbooks and found none of the sort, and I was wondering if any of you could please help :)
    I have drawn the graph y=x+2/x
    The solutions of the equation 2x+2/x=7 are the x-coordinates of the points of intersection of the graph of y=x+2/x and a straight line L.
    Fine the Equation of L.
    2. Relevant equations
    None
    3. The attempt at a solution
    My guess at the answer would be the equation of the line is y=7 as 2x+2/x=7 means y=2x+2/x=7 as far as I remember. I drew this line on my graph, getting a solution of x=0.3, put this back into the equation and got an answer of 7.23(recurring). Which I thought was close enough allowing for errors, but I really have no idea if it's right or anything, it's just a guess.
    Thanks in advance for any help :)
  3. Sep 15, 2007 #2
    Actually, first you need to simplify the equation 2x+2/x=7 to [tex]2x^2-7x+2=0[/tex]. This is a quadratic of the form [tex]ax^2+bx+c=0[/tex] where a=2, b=-7 and c=2.
    The two points you're looking for can be found by [tex]x=\frac{-b+\sqrt{b^2-4ac}}{2a}[/tex] and [tex]x=\frac{-b-\sqrt{b^2-4ac}}{2a}[/tex]
    Next, you plug in the two values you get from here into the equation y=x+2/x to get two values of y.
    Now, you have two points (x1,y1) and (x2,y2) (from your two values of x and y). Using these and the slope intercept form, you can find the equation of the line as such:
    [tex]y-y_1=\frac{y_2-y_1}{x_2-x_1}(x-x_1)[/tex]
  4. Sep 16, 2007 #3
    Thanks!
    Thanks alot! Just one question, the last formula you stated, I have never come across it before!! :P Mind explaining it?.. In the meantime, i'll try to figure it out myself, thanks alot though!
  5. Sep 16, 2007 #4
    HallsofIvy
    What eqaution would you use for a straight line through two given points?
  6. Sep 16, 2007 #5
    I'm sorry, I don't know. As far as equations of straight lines goes, i've only ever had to use the basic primary school formula rise/run, which I know is also delta y/delta x. I think I am beginnning to get the solution though, I have plotted the two points on my graph and if I join them I get a straight line. Now when I do this, the gradient of the line is 2.3recurring, which I round off to 2 considering errors, and the Y intercept is about 7. So I think the solution may be y=2x+7.
  7. Sep 16, 2007 #6
    symbolipoint
    Education Advisor
    Tigerd12, the straight line L would be some point (x, 7), which when you substitute y=7, would be the line which contains this point. You wrote:
    You are then looking for the solution to a quadratic equation. The solutions will be the x-intercepts, the x coordinates for y=0 (relax; you already made the substitution for y=7 to obtain the equation. You just use algebra to put the equation into the form ax^2 + bx + c =0). Chaoseverlasting gave the right approach.
    You will not really need the equation form for a line given in his message, but you likely need the knowledge as prerequisite development for the kind of question which you are working on; students learning about equations of lines before they learn about quadratic equations.
Similar Discussions: Graph + Algebra Question
  1. Graph algebra (Replies: 2)
Loading...
