Graph Theory Proof
Prove that all vertices of a complete graph Kn have deg(v) = (n-1)
∑ deg(v) = 2|E|
|E| = ½(n)(n-1) for Kn
I may have over thought this but this was my initial path at a formal proof.
Using the degree sum formula above and the formula for |E| for Kn,
∑ deg(v) = 2|E| = n(n-1)
Kn has n vertices so,
deg(v1) + deg(v2) + . . . . + deg(vn) (1/n) = (n-1)
∴ Each vertex , v, has degree (n-1)
EDIT: The degree sum formula was mistakenly labeled as the Handshaking lemma.
Answers and Replies
Interesting approach... it feels like you are using more advanced results to try to prove a simpler result, though - and that simpler result was perhaps used to prove the more complex results.
"A complete graph is a simple undirected graph in which every pair of distinct vertices is connected by a unique edge"
... that should be enough foundation to build your proof on.
7,994
∑ deg(v) = 2|E|
The above is incorrect. The 1/n factor is multiplying only the last term, deg(vn. I imagine that you meant this:
[deg(v1) + deg(v2) + . . . . + deg(vn)] (1/n) = (n-1)
In any case, what's your justification for dividing by n? It seems to me that this gives you the average number of vertex degrees.
In a complete graph with n vertices, each vertex must be connected to each other vertex. Thus, each vertex is connected to n - 1 vertices, so for each vertex v, deg(v) = n - 1. I'm not sure if you need to go into any more detail than this.
Ah ha! I just saw the degree sum formula and the edge formula for a complete graph and tried connecting the two to get the result I needed. I should have just went back to the definition of a complete graph. Derp!
Related Threads on Graph Theory Proof
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
