Graph theory trail proof
tarheelborn
123
Use ordinary induction on k or on the number of edges (one by one) to prove that a connected graph with 2k odd vertices composes into k trails if k > 0. Does this remain true without the connectedness hypothesis?
If k = 1, the resulting graph is [tex]K_2[/tex], the complete graph on two vertices, both of which have odd degree. If we add an edge connecting these 2 vertices, we obtain an Eulerian circuit. Removing one edge reduces the graph to exactly 1 trail. Assume this proposition holds for k >= 1. I need to show that it holds for [tex]k + 1[/tex], i.e., [tex]2(k + 1)[/tex] odd vertices. Let G be a graph with [tex]2(k+1)[/tex] odd vertices. Label these vertices as [tex]u_1, u_2, ..., u_2k+2[/tex].
And that's where I get stuck... I know that since G is connected, it contains trails, but I am not sure how to work this back to k trails...
(Sorry about the latex; I can't remember how to make it not break to a new line).
Answers and Replies
haruspex
Insights Author
8,217
Is it possible for a connected component to have an odd number of odd-valent vertices?
tarheelborn
123
No, a connected component cannot have an odd number of odd-valent vertices. Then could we say that since G cannot have an odd number of odd-valent vertices, there must be some (at least one) even-valent vertices which would indicate some (at least one) trails?
haruspex
Insights Author
8,217
Right, so how does the 2k total decompose across the components? What can you say about decomposition into trails in each component?
tarheelborn
123
A trail contributes even degree to every vertex, except that non-closed trails contribute odd degree to their endpoints. Thus a single trail can have, at most, two vertices of odd degree, so the composition of G contains 2k odd vertices, divided by 2 vertices per trail = k trails. That should do it, right? Thank you very much.
haruspex
Insights Author
8,217
That's not what I had in mind. You know that each component of G must have an even number of odd-valent vertices. Where that number > 0, the component decomposes into half that many trails. In that way, you decompose a disconnected graph with 2k odd-valent vertices into k trails provided... what?
tarheelborn
123
You are losing me here somewhat... I see that each trail has odd-valent vertices at its endpoints, so there would be two odd-valent vertices per trail. Then a graph with 2k odd-valent vertices would decompose into k trails provided the graph was Eulerian?
haruspex
Insights Author
8,217
In the OP, you say you know that if a graph is connected and has 2k > 0 odd-valent vertices then it decomposes into k trails. Suppose more generally that a graph has n connected components. We've established that each must have an even number 2ki of odd-valent vertices, Ʃki = k. If the ith component decomposes into ki trails then we're home, right? How might that not be so? What condition are we missing on ki?
tarheelborn
123
I think the ith component must have odd vertices; otherwise we have a circuit, not a trail.
haruspex
Insights Author
8,217
I'm not sure whether a trail is defined to have distinct endpoints. Maybe a circuit is just a special case of a trail? But even if a circuit is counted as a trail, you will still not be able to decompose the entire graph into k trails. Do you see why?
tarheelborn
123
The ith component would need odd vertices. Without that condition the graph could not be composed into k trails. Is that what you mean?
haruspex
Insights Author
8,217
Yes. E.g. Consider a graph consisting of two connected components, K2 and K3. It satisfies the criteria in the OP (k=1), but does not consist of a single trail.
Suggested for: Graph theory trail proof
  • Last Post
  • Last Post
  • Last Post
