Bachelier
- 376
I am trying to graph: r²= sinθ in Polar mode.
DMOC said:Did you change your calculator to use Polar GC and not Rect GC (assuming you're using a TI-83 or 84).
Office_Shredder said:It should only graph half. If theta is between pi and 2pi, sin(theta) is negative and no value of r will square to a negative number.
EDIT: Unless you allow negative r for a value of theta between pi and 2pi. In which case there's probably no way to graph this on your graphing calculator with a single equation
To enter an equation into a graphing calculator, first make sure the calculator is turned on. Then, locate the "Y=" button and press it. This will take you to the equation screen. Use the arrow keys to move to the desired equation slot and use the keyboard to enter the equation. Make sure to use the correct syntax for your calculator model. Once the equation is entered, press the "Enter" or "Graph" button to see the graph.
To adjust the window settings on a graphing calculator, press the "Window" button. This will take you to a menu where you can adjust the x and y ranges, as well as the scale and labels on the axes. Use the arrow keys to navigate and the number keys to enter values. Press "Enter" once you have made your adjustments. You can also use the "Zoom" button to quickly adjust the window to fit your graph.
Yes, most graphing calculators have a built-in solver function that can be accessed through the "Math" or "Calc" menu. Simply enter the equation you want to solve and press "Enter". The calculator will usually give you the option to solve for a specific variable or solve the equation numerically.
To graph multiple equations on a single graph, enter each equation into a different slot on the "Y=" screen. Then, use the arrow keys to select each equation and press "Enter" to graph it. You can also use the "Trace" or "Table" function to see the points of intersection between the different graphs.
Most graphing calculators have the ability to connect to a computer via USB cable. Check your calculator's manual for specific instructions on how to transfer graphs. Once connected, you can use software such as TI Connect or graphing calculator emulators to save and transfer your graphs to your computer.
