Graphing circular functions
In summary, to find the relevant intercepts and coordinates of turning points for a graph like -3cos(1/2(theta- 3π/2) + 2 with a domain of [-π, π], you can use the basic properties of a cosine function and mark key points on the graph to determine the starting and ending points of a single period. For the equation 100cos[π(x-400)/600]+30 for 0<x<1600, you can use similar methods to find the x-intercepts and also determine the midpoint and quarter points. Finally, to differentiate the equation V= π(h+1)[(ln(h+1))² + h], you can use the product rule and chain
ScienceNewb
1. For graph like -3cos(1/2(theta- 3π/2) + 2 what's the best method for finding the relevant intercepts and coordinates of turning points and such? domain being equal to [-π, π]. Also if it were different domain would that only affect the end points in my calculation?
2. For 100cos[π(x-400)/600]+30 for 0<x<1600 I tried finding the x-intercepts of this equation by hand by finding the inverse cos of -3/10 then solving for x but that only gives me the second intercept of 758... how do I get the first intercept at 41.8?
Also I tried to find the integral of 100cos[π(x-400)/600]+50 for boundaries 800 to 1200 and received the answer of 59937.66 when it should be 13080, what mistake did I make?
3. How do I differentiate V= π(h+1)[(ln(h+1))² + h]?
Anyone? I'm really just concerned with number 1 as I need a solution to continue my studies...
The basic "y= cos(x)" has "amplitude 1", period [itex]2\pi[/itex], and goes through (0, 0).
In y= A cos(mx+ b)+ c, the "A" 'stretches' the amplitude while the "c" 'moves' the graph up or down. Since the period of cos(x) is 0 to [itex]2\pi[/itex] you need to look at mx+ b= 0 and [itex]mx+ b= 2\pi[/itex] to find starting and ending values for a single period.
In, for example, [itex]y= -3 cos(1/2(\theta- 3\pi/2)+ 2[/itex], the amplitude is 3. [itex]1/2(\theta- 3\pi/2)= 1/2\theta- 3\pi/4= 0[/itex] when [itex]1/2\theta= 3\pi/4[/itex] so [itex]\theta= 3\pi/2[/itex] and [itex]1/2\theta- 3\pi/4= 2\pi[/itex] when [itex]1/2\theta= 5\pi/4[/itex] so [itex]theta= 5\pi/2[/itex].
I would recommend marking [itex]x= 3\pi/2[/itex] and [itex]x= 5\pi/2[/itex] on the x-axis. Also mark halfway between them: [itex](3\pi/2+ 5\pi/2)/2= 8\pi/4= 2\pi[/itex] as well as the "quarter points" [itex](3\pi/2+ 2\pi)/2= 7\pi/4[/itex] and [itex](2\pi+ 5\pi/4)/2= 9\pi/4[/itex].
Now, the lowest value of cos(x) is -1 so the highest value of -3 cos(x) is 3 and the highest value -3 cos(x)+ 2 is 5. The highest value of cos(x) is 1 so the lowest value of -3 cos(x) is -3 and the lowest value of -3cos(x)+ 2 is -1. Draw light erasable horizontal lines at y= -1 and y= 5.
You should have an idea of what the graph of the base function, cos(x), looks like. It starts each period at y= 1, drops down to 0 1/4 of the way through the period, then -1 half way, back up to 0 3/4 of the way, ending the period at y= 1 again. Since the coefficient of cosine is negative for this function, that pattern is reversed. The graph will start at y=-1, go up to 0 and then y= 5, drop down through 0 to -1 again.
When [itex]\theta= 3\pi/2[/itex], calculated above as the starting value for one period, the value inside the cosine is x= 0 so the 'beginning point", is at [itex](3\pi/2, -1)[/itex]. When [itex]\theta= 5\pi/2[/itex], calculated above as the ending value for one period, the inside the cosine is [itex]2\pi[/itex] so the 'ending point" is at [itex](5\pi/2, -1)[/itex]. At the midpoint, the graph is at [itex](2\pi, 5)[/itex]. At the "quarter points", y is half way between -1 and 5, (-1+ 5)/2= 2. Mark those five points and draw the "cosine shape" between them. You can repeat that due to the periodicity of the cosine.
First, the highest y value for this graph is 100+ 30= 130 and the lowest is -100+ 30= -70. Draw light horizontal lines at y= -70 and y= 130 as guides.
[itex]\pi(x-400)/600= 0[/itex] when [itex])\pi(x- 400)= 0[/itex] or [itex]x= 400[/itex]. One period will start at [itex](400, 100+ 30)= (400, 130)[/itex]. [itex]\pi(x- 400)/600= 2\pi[/itex] when [itex]x- 400= 2/600= 1/300[/itex] or [itex]x= 400+ 1/300[/itex]. On period will end at (400+1/300, 100+ 30)= (400+ 1/300, 130). Midway between 400 and 400+ 1/300 is 400+ 1/600. At that point the cosine will be -1 so the midpoint of the graph is at (400+ 1/300,-100+ 30)= (400+ 1/300, -70). The two "quarter points" are at 400+ 1/1200 and 400+ 1/600+ 1/1200= 400+ 1/400. cosine there is 0 so the quarter points are (400+ 1/1200, 30) and (400+ 1/400, 30).
How can anyone possibly tell you want mistake you made if you don't tell us what you did!?
Well, using the product rule and the chain rule, of course,
[tex]V'= \pi((h+1)'[(ln(h+1))^2+ h]+ (h+1)[2(ln(h+1))\frac{1}{h+1}+ 1][/tex]
What is a circular function?
A circular function is a mathematical function that involves the use of a circle, such as sine, cosine, and tangent.
Why is graphing circular functions important?
Graphing circular functions is important because it allows us to visualize and understand the behavior and relationships of circular functions. It also helps us to solve equations involving circular functions.
What are the key features of a graph of a circular function?
The key features of a graph of a circular function include the amplitude, period, phase shift, and vertical shift.
How do you graph a circular function?
To graph a circular function, first identify the key features of the function. Then, plot points using the x and y coordinates based on the key features. Finally, connect the points to create a smooth curve.
What are the common mistakes to avoid when graphing circular functions?
Common mistakes to avoid when graphing circular functions include not correctly identifying the key features, using incorrect scales on the x and y axes, and not plotting enough points to accurately represent the function.
