How can completing the square help with graphing transformations?
In summary, the conversation discusses how to graph the function f(x)=x^2+4x+3 by starting with the graph of y=x^2 and using transformations. The participants mention that the graph will open up, but one person is having trouble understanding transformations and how to solve them. They suggest using the function f(x-a) to move the graph right by a units, a*f(x) to stretch the graph by a factor of "a", f(ax) to increase the frequency of the graph "a" times, and f(x)-a to move the graph down by "a" units. They also advise using the completed square form to better visualize the problem. The conversation ends with the advice to complete the square for
shoook
23
1. Graph the function f(x)=x^2+4x+3 by starting with the graph of y=x^2 and using transformations.
2.
3. I know the graph opens up, but I don't understand transformations or how to solve them, any help would be greatly appreciated.
For any function f(x), f(x-a) moves the graph right by a units, a*f(x) stretches the graph by a factor of "a", f(ax) increases the frequency of the graph "a" times, f(x)-a moves a graph down by "a" units.
Well to help you see better change f(x) into the completed square form
If you think physically (i.e. like a freefall problem), you can almost immediately pick out the meaning of the constant 3 term and the 4x term... then transform the original y=x^2 appropriately.
To repeat the very good advice of rock_freak667, complete the square- and it all shall be made clear to you!
What is the purpose of graphing transformations?
The purpose of graphing transformations is to visually represent how a function is affected by various changes to its equation. It allows us to better understand the behavior of the function and make predictions about its values.
What are the different types of transformations that can be applied to a graph?
The main types of transformations that can be applied to a graph are translations, reflections, dilations, and rotations. Translations shift the graph horizontally or vertically, reflections flip the graph across an axis, dilations stretch or shrink the graph, and rotations rotate the graph around a point.
How is a graph affected by a translation?
A translation involves shifting the graph horizontally or vertically. If the translation is in the form of (a, b), the graph will shift a units to the right if a is positive, and a units to the left if a is negative. Similarly, the graph will shift b units up if b is positive, and b units down if b is negative.
What is the difference between a horizontal and vertical reflection?
A horizontal reflection flips the graph across the x-axis, while a vertical reflection flips the graph across the y-axis. This means that the x-coordinates of the points on the graph remain the same for a horizontal reflection, but the y-coordinates change. Similarly, the y-coordinates remain the same for a vertical reflection, but the x-coordinates change.
How does a graph change when dilated?
When a graph is dilated, it is either stretched or shrunk. A dilation with a scale factor greater than 1 results in a stretched graph, while a scale factor between 0 and 1 results in a shrunk graph. The center of dilation is also an important factor, as it determines the direction and amount of stretching or shrinking.
  • Precalculus Mathematics Homework Help
