Analysisfreak
- 2
The graph of g is interm of f. So how to plot g(x)= f(|x|) and of g(x)=|f(x)|. Is it jus a 'V' shape one.This problem is in Spivak Textbook, Chapter 4. Thanks to all.
An absolute function is a type of mathematical function that is defined as f(x) = |x|, where |x| represents the absolute value of x. This function outputs the positive value of any input, regardless of whether the input is positive or negative.
To graph an absolute function, you can plot points by choosing various values for x and finding the corresponding y values using the function f(x) = |x|. The graph will consist of two straight lines intersecting at the origin, with the line passing through the origin having a slope of 1.
The domain of an absolute function is all real numbers, as any value of x can be plugged into the function. The range of an absolute function is also all real numbers, but the output will always be a positive value.
To solve an equation involving an absolute function, you can split the equation into two separate equations, one with the positive input and one with the negative input. Then, you can solve for both cases and find the solution set by combining the two sets of solutions.
Absolute functions can be used to model various real-life scenarios, such as calculating distance, velocity, and acceleration in physics problems. They can also be used in economics to analyze production and cost functions, as well as in computer science to create algorithms for data processing and optimization.
