Fractional Weight Reduction from Gravitational Attraction of Water Tank
  • Thread starter tnutty
  • Tags
    Attraction
In summary, the gravitational attraction of the water in a water tank reduces the weight of an object by a fraction. This fraction is dependent on the mass of the object and the distance from the center of the water tank.
tnutty
326
If you're standing on the ground 17 m directly below the center of a spherical water tank containing 6.0×106kg of water, by what fraction is your weight reduced due to the gravitational attraction of the water?
F = GMm/r^2
not sure where to start.
anyone?
So that equation gives you the gravitational attraction force. You can use it to calculate the force between u and the water tank, between u and the earth, etc.
The tank and Earth are both spheres, so u can use Gauss's law and symmetry..
Still a little confused.
I get I need to calculate the force between the tank and I . but then I am confused on where to go.
You can calculate the force between you and the water tank, then do the same thing between you and the Earth (which should essentially be F=ma) and compare. The centre of the water tank directly opposes the centre of the Earth so they are opposite forces. The effect of the water tank will be very minor, but still interesting to calculate. If what I said does not make sense let me know and I will try to reword it all. Also, weight is a measure of force, so by comparing the two forces you can solve.
I don't have my mechanics text near me for the constants, but if you calculate the force exerted by the tank and subtract it from the force exerted by the Earth then the resulting force is your weight in Newtons
so,
F_g_t = GMm/r^2
= G(6.0*10^6) M_p / 17^2
and
F_g_e = GMm/r^2
G(5.98*10^24)M_p / (6378.1)^2
is this the correct step so far?
If so then what should I do next?
It might have been easier to solve it as variables first.
For instance they want the ratio of the forces, so ...
F/Fo = (Gm(M_tank)/d2)/Gm(M_earth)/R_earth2)
Simplifying you have
Ratio = M_tank*R_earth2/M_earth*d2
Then just calculate.
M_tank = 6.0 *10^6
M_earth = 5.98 * 10^24
d = 17m
r_e = 6.37 * 10^6
my answer came out as 5.58 * 10^-8
But I guess this is wrong
forget it this is solved. I miscalculated. Thanks
1 question. Why is it the force of Earth over the force of the spherical tank?
Why does that give you the fraction of you weight reduced?
Look again. The Mass of the Tank is in the numerator, Earth below. Do the algebra for dividing the expressions for gravity and you will see.
As to the fraction ...
they want ΔF / F
ΔF = Ft
alright thanks, but I am not sure how f1/f2 gives you the fraction of your reduced weight.
Although I get the math, I don't get the concept of this problem. Would you
mind explaining why a force over another force gives you a fraction of one's reduced weight?
F_t = (m_t)(a_t)
F_e = (m_e)(a_e)
(m_t)(a_t)
(m_e)(a_t)
I get that this gives you a fraction. And that this fraction gives you how
much you weight relative to the Earth ...something?
but how does it tell you how much less you weight.
Can you add some context to the math that you did above?
I am sorry I am still not getting it.
Consider you are measuring some mass m's weight.
F = m*g
Well that is also G*M*m/r2
That's weight.
Now they also set you underneath the old town water tank. That has a prodigious mass. And as we know masses have attractiveness to each other and that attractiveness in this case is up.
So ... if it is going up that means it is reducing the weight measured down.
What is the difference in that weight as a fraction of the weight? Well I'd say it's the weight (force) up divided by the weight down. The weight up is your difference in weight, and the weight down is as before nothing changed from weighing the mass in an open flat parking lot.
OH, nice. Thanks a lot. You know I don't just want to memorize formula's. I want to understand it so that's why I ask. I am thankful for you explanation.
What is gravitational attraction?
Gravitational attraction is a force that exists between any two objects with mass. It is an attractive force that pulls objects towards each other.
How does gravitational attraction work?
Gravitational attraction is a result of the curvature of space and time caused by massive objects. The more massive an object is, the stronger its gravitational pull will be. Objects with greater distance between them have a weaker gravitational attraction.
What is the formula for gravitational attraction?
The formula for gravitational attraction is F = G * (m1 * m2) / r^2, where F is the force of attraction, G is the gravitational constant, m1 and m2 are the masses of the two objects, and r is the distance between them.
How does distance affect gravitational attraction?
The force of gravitational attraction is inversely proportional to the square of the distance between two objects. This means that as the distance between two objects increases, the force of attraction decreases.
What are the real-life applications of gravitational attraction?
Gravitational attraction is responsible for keeping our solar system together, as well as for tides on Earth and the moon's orbit around our planet. It is also a crucial factor in space travel and satellite communication.
