Gravitational attraction
  • Thread starter zd1899
Suppose that in free space , dust particles are evenly distributed all around.
Amidst the dust particles , there are two identical spherical cavities at some distance from each other. Do you think they will attract each other or repel or just be as they were??
Answers and Replies
Vanadium 50
Staff Emeritus
Education Advisor
27,637
11,842
They repel. (Wrong....see below)
And may i know how? I always think that they would attract each other as the mass around the spheres would try and close on in , i was thinking of going about this by using the principle of superposition but still couldnt get a conclusion.
Vanadium 50
Staff Emeritus
Education Advisor
27,637
11,842
Oops....sign error.
Hold one bubble fixed. Consider the force on the second bubble. If the first bubble didn't exist, there would be no force on the second. Since there is a gap, the gravitational force points away from the bubble. So the dust moves in that direction, away from the bubble, which means that the void moves towards it.
Hey thanks that cleared a lot up.
Vanadium 50
Staff Emeritus
Education Advisor
27,637
11,842
Another way you can think of it is to treat the dust as massless, and the bubbles as having negative mass. The force points in the opposite direction, so the acceleration points in the same direction: the bubbles attract.
DaveC426913
3,289
What are these cavities composed of? Are they simply voids in the distribution of the particles? Is there anything holding them rigid? Is there anything holding the particles from filling them?
Yes , they are simply voids. The Dust particles are distributed uniformly and there are two nearby spherical voids.
DaveC426913
3,289
Then it is folly to pretend they act as an object. The particles will uniformaly distribute themselves within them.
A.T.
2,731
Even if all particles are initially at rest?
Danger
251
Won't all of the dust particles attract each other into a assemblage, thus merging the voids into one huge one that surrounds the object? (No offense, Vanadium, but the original question didn't assume the dust to be massless.)
A.T.
2,731
Yeah, I guess dust particles with empty space between are quite different from a fluid, which cannot be compressed or vaporize. How would they behave with only one spherical cavity, when initially all are at rest?
DaveC426913
3,289
They cannot be at rest; they must have some thermal energy.
A.T.
2,731
Why?
Why?
Because if they lacked thermal energy, and they were at rest, you would pretty much know everything about them with certainty (position, velocity, energy) which violates the uncertainty principle
A.T.
2,731
I was thinking more in terms of larger particles so I omitted this. How would they behave classically without quantum effects, just gravity.
DaveC426913
3,289
OK, I see where you're going.
The particles adjacent to the voids feel an imbalanced gravitational pull. The net effect is that they are pulled away from the voids, causing the voids to grow. The particles between the two voids have this imbalance ... uh ... balanced. They feel no pull towards or ways from the two voids, but they do feel a very small pull outward, as if being squeezed out from between the two voids.
The net effect is that the voids will grow until they are separated by a thin filament of particles.
If we expanded the model to include multiple voids in a 3D volume, we would see all voids grow until they were separated only by thin, dense filaments. Ultimately, the volume would be less "voids in a sea of particles" and more "empty space shot through with filaments", like a cobweb in a box.
Interestingly, this is exactly what is http://images.google.com/images?q=g...oe=utf8&rlz=&um=1&ie=UTF-8&sa=N&hl=en&tab=wi".
Surface tension has a role?
Hey! I just found out that its an ex Physics olympiad problem.
The dust configuration remains constant , wont move in. So we can do this using the potential energy concept for the sphere's i.e. they would try and reduce their respective energies.
Related Threads on Gravitational attraction
  • Last Post
  • Last Post
  • Last Post
  • Poll
  • Last Post
  • Last Post
  • Last Post
