Gravitational Double Slit Experiment: What Does Modern Physics Say?
In summary, the conversation discusses the possibility of conducting a double slit experiment with a gravitational wave detector instead of an electromagnetic wave detector. While it seems unlikely that such an experiment could be conducted in the near future, there is speculation about the behavior of gravitons and the potential for using refractive barriers to conduct the experiment. Some participants mention the equivalence principle and the effect of low gravity on the behavior of gravitational waves, but the feasibility and potential results of the experiment remain uncertain.
drag
Greetings !
I see that my original thread called "Uncertain Gravity?"
did not get the attention that I hoped it would (a level
at least sufficient to answer the question I'm now separately
posting here).
So, the question:
What does modern physics say about the double slit experiment
where a gravitational wave detector is placed near a slit
instead of an EM wave detector (or a nuclear detector since
the weak and strong forces have been included in later theories
that deal with them based on the quantum approach) ?
(And if you don't know that, then - what do you think ?)
Thanks ! :smile:
Live long and prosper.
Don't know what 'current science' says, but if I recall it properly a gravitational wave detector is being built in the US, it is called LIGO for Large Interferometry Gravitational Observatory, and if I recall again correctly, it is rather huge, (Mile{s} long) not something that you could place in a lab behind the double slit experiment, if that is the one you talking about.
Otherwise, sorry to take up your time. My 2 ¢
EDIT SP! x 2
I don't quite understand this. How do you diffract gravity waves if as far as we know there is no way to shield from gravity or change it's rate of propagation?
where a gravitational wave detector is placed near a slit...
Since gravity couples to everything, it seems unlikely that a consistent TOE could be constructed that allows gravity to escape governance by the quantum rules that govern everything else. For this reason, such theories haven't been pursued. In fact, the converse issue of what the implications of quantization are for GR, and in particular, for the principle of equivalence and diffeomorphism invariance is a common worry.
The problem of diffeomorphism invariance doesn't lend itself well to you're question, but I have seen the issue of the equivalence principle dealt with in terms of, for example, particles diffracted by a "gravitational grating". However the results of such gedanken experiments don't throw the equivalence principle into doubt.
Well, that is the sticky in the wicket, no? Perhaps the two slits could be in a berrier of Bose-Einstein Condensate (if these are shown to "block" gravity, which I find hard to accept).
Greetings !
jeff, thanks for your response. :smile:
Could you, please, tell us a bit more about what
"diffeomorphism invariance" is and how exactly the
equivalence principle is related here (for the poor
hobbyists amongst us, like me ).
But you can alter the course and shape of the wave, right ?
So, suppose you have a nutron going through a slit and you send
a gravity wave. The nutron itself also bends space-time so
the wave should be somehow affected by it in the above manner
(I guess ).
The question is, will this "detection" collapse the WF ?
If not, what will it detect ? And will this mean that
we can get around the HUP through GR and find out what
that QM "mess" is all about ?
in a low gravity limit it is possible to construct a quantum field theory of gravitons - whether this is valid or not remains to be tested - so if a single graviton was diffracted through some version of the double slit experiment, it would act "exactly like a photon" in a similar experiment.
As stated above, it might be possible to set up refractive barriers that allow slit like experiments to b e conducted.
Joe
Greetings !
Originally posted by Andersen
in a low gravity limit ...
What do you mean by "low gravity limmit" ?
And why is that ?
Actualy, I'm just asking about the theory of what will happen.
Like I said before - I don't think that such an experiment will
be practicly possible any time soon (and that's probably
an understatement :wink:). But, if someone got an idea on
how to do it - go right ahead and tell us ! :smile:
[Oopsey... What was I thinking?]
Gravity having an effect on gravity? Hmm.. certainly a novel idea...
Can this be tested somehow?
I'm not certain what precisely is the problem here.
This is not a novel idea at all.
Greetings !
And why is that ?
my recollection of the details is fuzzy - but:
at low enough gravity you can neglect nonlinearities, and then vibrations in space time obey equations analogous to light - which are then amenable to quantization as per the standard methods of QM -> gravitons.
It is possible that a gravitational version of an einstein ring (big GW source behind massive object could yeild some sort of interfenernec epattern in GW's - not positive how you could measure the pattern with ligo though
Joe
Any other opinions on this ? :smile:
1. What is the "Gravitational Double Slit" experiment?
The "Gravitational Double Slit" experiment is a thought experiment that explores the behavior of particles in the presence of gravity. It is similar to the well-known double slit experiment in optics, but instead of studying the behavior of light, it examines the influence of gravity on particles such as electrons or atoms.
2. How does the "Gravitational Double Slit" experiment work?
In the "Gravitational Double Slit" experiment, a beam of particles is directed towards a barrier with two slits. Behind the barrier, there is a screen that detects the particles that pass through the slits. The particles behave like waves and create an interference pattern on the screen, showing that they have wave-like properties even in the presence of gravity.
3. What is the significance of the "Gravitational Double Slit" experiment?
The "Gravitational Double Slit" experiment highlights the wave-particle duality of matter, which is a fundamental concept in quantum mechanics. It also demonstrates that gravity can affect the behavior of particles, even at the quantum level. This experiment has important implications for our understanding of the universe and the laws of physics.
4. What are some real-world applications of the "Gravitational Double Slit" experiment?
While the "Gravitational Double Slit" experiment is a thought experiment, it has real-world applications in fields such as quantum computing and quantum cryptography. The behavior of particles in the presence of gravity is important in understanding and developing these technologies.
5. Are there any limitations to the "Gravitational Double Slit" experiment?
Like any thought experiment, the "Gravitational Double Slit" experiment has its limitations. It does not fully explain the behavior of particles in the presence of gravity, and there are still unanswered questions and debates surrounding it. Additionally, it is a simplified model and does not take into account the complexities of the real world, such as the effects of other forces and interactions between particles.
  • Quantum Physics
  • Quantum Physics
  • Quantum Physics
  • Quantum Physics
