Gravitational Effect from Relativistic Mass: Answers & Questions
In summary, relativistic mass does not make a proportional gravitational effect on an observer. Objects with relativistic mass move faster than slower objects and thus deflect the path of the observer more than a naive Newtonian calculation would suggest. However, the effect is small and does not convert the object to a black hole.
stefanbanev
50
TL;DR Summary
Does relativistic mass make a proportional gravitational effect on observer it flies by?
Does relativistic mass make a proportional gravitational effect on observer it flies by? Does 1 ton (resting 1 ton) of lead moving relatively observer at some speed close enough to C may appear as a micro black hole? What abort Hawking radiation in this case? Does it mean that we may convert any mass to energy via Hawking radiation simply by speeding up such mass fast enough? How relativistic mass contributes to total mass of observable universe? ~13.8+ billion light years away any proton must have ~infinite mass relatively Earth' observer; does it meant that universe has an infinite mass relatively Earth' observer?
No. Speed is relative. You are currently moving at 0.999999c relative to a high energy cosmic ray, so according to it you have a huge relativistic mass. Do you feel like a black hole?
It doesn't. The concept doesn't translate simply to the case of curved spacetime, even if one persists in using it in special relativity.
This kind of misconception is one of the reasons that relativistic mass has been a deprecated concept for decades. Popsci sources have not caught on, sadly.
Likes lomidrevo
...that said, with a lot of caveats, a mass moving relative to you does deflect your path more than a naive Newtonian calculation would suggest. The last time this came up, @pervect suggested:
pervect said:
I believe you get up to a factor of 2 "greater mass" from something approaching the speed of light. This is not relevant to your cosmological example.
Likes FactChecker
stefanbanev said:
Summary: Does relativistic mass make a proportional gravitational effect on observer it flies by?
It winds up having more than a proportional effect, if one measures the effect by the velocity induced by the relativistic flyby. See for instance Olson, D.W.; Guarino, R. C. (1985). "Measuring the active gravitational mass of a moving object". In the ultra-relativistic case, the moving mass induces nearly twice as much veloicty change as a slower-moving object with the same energy . ( Energy a synonym for relativistic mass that I greatly prefer to use).
No. Whether an object is a black hole or not is a different question than asking how much velocity a relativistic flyby induces in an observer. Being a black hole is a frame-independent property, so an object that is not a black hole in it's rest frame is not a black hole in any frame.
The accretion disk of a black hole radiates much of the energy of infalling matter away before the matter reaches the black hole, without any need for hawking radiation, which is a tiny quantum effect.
Basically, as dust falls into the black hole, it speeds up, and collisions between the dust particles heat them up, causing them to radiate energy away.
To do this to an object effectivel, one might have to break it up into pieces, first, so the pieces can hit each other.
The "mass of the observable universe" isn't really well defined. One could come up with a coordinate dependent figure by insisting that one use the standard cosmological coordinates, but one wouldn't get the same number in other coordinates.
pervect said:
... without any need for hawking radiation, which is a tiny quantum effect.
"Tiny" for normal BH not for micro BH. The BH with 1-ton of resting mass would evaporate in seconds (if not microseconds), converting all its mass into energy with 100% of efficiency. Well, it would be a quite spectacular manifestation of "tiny" effect ;o)
Regarding to ultra fast non-zero-mass particles with speed above some C*0.99999999999... threshold which may make such particles heavy enough to make a noticeable tide-effect on observer, long before that it becomes a femto/yocto-BH which evaporates. So, it implies that the energy/speed for non-zero-mass particles has an upper limit because of Hawking radiation. Pls correct me if I'm wrong...
Something moving ultrareletivistically relative to you does not appear like or become a BH. Full stop. Your whole premise is simply false.
Likes Ibix
And with that, this thread is closed.
1. What is the concept of gravitational effect from relativistic mass?
The concept of gravitational effect from relativistic mass is based on Einstein's theory of relativity, which states that mass and energy are interchangeable. This means that as an object's velocity increases, its mass also increases. This increase in mass leads to a stronger gravitational pull on surrounding objects, resulting in a gravitational effect.
2. How does the gravitational effect from relativistic mass differ from traditional gravity?
The traditional concept of gravity is based on Newton's law of universal gravitation, which states that the force of gravity between two objects is directly proportional to their masses and inversely proportional to the square of the distance between them. However, the gravitational effect from relativistic mass takes into account the increase in mass due to an object's velocity, resulting in a stronger gravitational force.
3. Can the gravitational effect from relativistic mass be observed in everyday life?
Yes, the gravitational effect from relativistic mass can be observed in everyday life. For example, the GPS system would not work accurately without taking into account the relativistic mass of satellites in orbit. Additionally, the bending of light around massive objects, known as gravitational lensing, is also a result of the gravitational effect from relativistic mass.
4. How does the gravitational effect from relativistic mass impact the behavior of objects in space?
The gravitational effect from relativistic mass can significantly impact the behavior of objects in space. As an object's velocity increases, its mass also increases, resulting in a stronger gravitational pull. This can affect the orbits of nearby objects and can even cause objects to collide or merge due to the increased gravitational force.
5. Is the gravitational effect from relativistic mass a significant factor in the universe?
Yes, the gravitational effect from relativistic mass is a significant factor in the universe. It plays a crucial role in shaping the structure of the universe, from the formation of galaxies to the movement of objects in space. It also helps us understand the behavior of massive objects, such as black holes, and their impact on surrounding matter.
