1. PF Contest - Win "Conquering the Physics GRE" book! Click Here to Enter
Gravitational Energy
  1. Mar 13, 2014 #1
    In nature, all forces have a limited value, i.e, their effect is reduced if many objects are influenced by that force. Example, the magnetic force experienced by a single iron nail (in a magnetic field) is greater than that of 2 iron nails in the same field.
    Consider gravity,
    gravity exerts a force that is related to our mass. Now, on Earth, there are millions of people but everyone experiences the same force even if there are billions or trillions. That means, gravity has infinite potential.
    How is this possible?
    Thanks for replying
  3. Mar 13, 2014 #2
    Staff Emeritus
    I'm not sure this is correct. I can see it if you put the nails end to end so that one is further away from the magnet, but not if they are placed at the same distance.
    The electromagnetic force is not the same as gravitation. The EM force has two charges which complicates things. For example, you can "screen" a positively charged particle from the electric field of a negatively charged particle by having another positively charged particle between them. That's why you can have objects which are electrically neutral. This is not possible with gravitation.
    In gravitation there is only one "charge" and it is only attractive. It cannot be screened like the EM force can. So adding people onto the Earth will actually ADD to the gravitational force, not reduce it.
    In addition, the gravitational potential energy for any one object is never infinite. You can boost an object from the surface of the Earth to infinity by accelerating it to escape velocity. For the Earth, this velocity is equal to about 25,000 mph.
  4. Mar 13, 2014 #3
    Staff: Mentor
    The Earth's potential is finite. You only get an infinite potential for a classical point mass, and Earth is not a point mass.
    Also, this is the same for electromagnetism. A classical point charge has an infinite potential also, and a non-point charge has a finite potential.
    Luckily, classical point sources do not exist.
  5. Mar 14, 2014 #4
    I do not understand the point of earth not being a point mass. I mean, how does a point mass and earth differ in action of gravity (wrt the question).
    And, by saying that earth's potential is finite, do you mean that for every baby born, the gravitational force on me decreases by infinitely small amount?
  6. Mar 14, 2014 #5
    If the babies immediately crawl away from you.
  7. Mar 14, 2014 #6
    Staff: Mentor
    The potential energy density of a gravitational field is given by ##u=-\frac{|\mathbf{g}|}{8\pi G}##. If you evaluate that for a uniform spherical ball then you get
    $$U=\int u\;dV = -\frac{3GM^2}{5R}$$
    Where G is the universal gravitational constant, M is the mass of the ball, and R is the radius of the ball. This number is finite for R>0, and infinite for R=0 (a point mass). Therefore the Earth's gravitational potential energy is finite but the gravitational potential energy of a point mass is not.
    Yes. The mass of the earth goes down and therefore its gravitational potential energy goes down. However, the baby also has a gravitational force and the baby's gravitational potential energy goes up by the same amount that the earth's potential energy goes down since the baby's mass is the same as the mass removed from the earth. So it really is a complete non-issue.
  8. Mar 14, 2014 #7
    Right there is your mistake. That's just not true.
  9. Mar 14, 2014 #8
    Andrew Mason
    For every baby that is born and then taken away by aliens to the distant mothership, gravity decreases. Otherwise a new born baby is just a rearrangement of existing matter.
  10. Mar 14, 2014 #9
    Andrew Mason
    I think the OP has in mind a mechanical force. I apply a force F to a mass m, and get acceleration a but if I apply it to 2m I get a/2 for acceleration.
    For gravitational and electromagnetic fields, the force is different because the magnitude of the force is proportional not only to the field but to the magnitude of the mass or charge of the bodies in that field: F = mg or F = qE.
  11. Mar 15, 2014 #10
    The OP seems to think that more people being born should reduce Earth's effect on me just like more guests coming in means less soup for me. It doesn't work that way.
Similar Threads - Gravitational Energy Date
I Self-gravitating ball of gas Jan 25, 2018
I GPE and escape velocity Aug 29, 2017
I Amount of excess charge to overcome Earth's gravity Mar 14, 2017
I Understanding gravitational potential due to spherical shell Aug 27, 2016
