1. Not finding help here? Sign up for a free 30min tutor trial with Chegg Tutors
Gravitational field
  1. May 11, 2008 #1
    [SOLVED] gravitational field
    How much work is done by the Moon's gravitational field as a 1100kg meteor comes in from outer space and impacts on the Moon's surface?
    2. Relevant equations
    W=GMm/r
    3. The attempt at a solution
    W=6.67 X 10^-11(6 X 10^22)(1100kg)/1.5 X 10^6
    =2.9 X 10^9
    Thank you very much
  3. May 11, 2008 #2
    G01
    You should be getting the correct answer as long as the numbers you're using are correct. Check that value for the radius of the moon. Shouldn't it be 1.7*10^6 m? If so, your answer may be off a little bit.
  4. May 11, 2008 #3
    Thank you very much
    Regards
Similar Discussions: Gravitational field
  1. Gravitational Field (Replies: 1)
  2. The Gravitational Field (Replies: 11)
  3. Gravitational fields (Replies: 2)
  4. Gravitational fields (Replies: 1)
  5. Gravitational fields (Replies: 23)
Loading...
