alyafey22
MHB
- 1,561
Sometimes we hear 9.8 m/s^2 and sometimes 10 m\s^2 ?? what is the most correct and how did they manage to find it?
The correct value for g0 is 9.80665 m/s2, exactly.cepheid said:Note: you often hear it stated that g = 9.81 m/s2. I guess it depends on how you decide what should be the typical value.
9.80665 m/s2 is a defined value.It was determined experimentally.
Watch out for that.Check out http://www.google.ca/search?hl=en&c...arth)/(radius+of+earth)^2&aq=f&aqi=&aql=&oq=" (click on the link)
D H said:The correct value for g0 is 9.80665 m/s2, exactly.
http://www.bipm.org/en/CGPM/db/3/2/.
Earth gravity (which conventionally includes centrifugal acceleration due to the Earth's rotation) varies with latitude, altitude, and location. Local acceleration due to gravity is about 9.780 m/s2 at the sea level at the equator, 9.832 m/s2 at sea level at the poles, and 9.779 m/s2 in Mexico City.
Gravitational acceleration, including centrifugal acceleration, can be measured extremely precisely with gravimeters, which are essentially a kind of accelerometer.
Watch out for that.
Google calculator has a lousy value for G and for the Earth's mass.
G, per google's calculator, is 6.67300×10-11 m3/kg/s2. The correct value is 6.67428(67)×10-11 m3/kg/s2 (see http://www.physics.nist.gov/cgi-bin/cuu/Value?bg).
Earth's mass, per google's calculator, is 5.9742×1024 kilograms. The agreed-upon value is 5.97219x1024 kg (see http://solarsystem.nasa.gov/planets/profile.cfm?Object=Earth&Display=Facts).
Rather than using those lousy values for G and Mearth, it is much better to use μearth = G*Mearth = 3.986004418(8)x1014 m3/s2 (see http://www.iers.org/nn_11216/SharedDocs/Publikationen/EN/IERS/Publications/tn/TechnNote32/tn32__009,templateId=raw,property=publicationFile.pdf/tn32_009.pdf , table 1.1). While G and Mearth have an error of about 1 part in 7,000, the product of the two has an error of about 1 part in 500 million.
The google calculator value for this product is 3.98658366×1014 m3/s2. If they are going to use bad values, they should at least be consistent.
Gravitational force is a natural phenomenon by which all objects with mass are brought towards each other. It is the force responsible for the attraction between objects, such as the Earth and the Moon.
Gravitational force is measured in units of newtons (N). It can be calculated using the equation F = G(m1m2)/r^2, where G is the gravitational constant, m1 and m2 are the masses of the two objects, and r is the distance between them.
The value of the gravitational force on Earth is approximately 9.8 m/s^2. This is often rounded to 10 m/s^2 for simplicity.
Yes, gravitational force varies on different planets based on their mass and size. For example, the gravitational force on the surface of Mars is only about 38% of that on Earth.
Gravitational force cannot be manipulated or controlled by humans. However, the effects of gravity can be counteracted through the use of technology, such as rockets and spacecraft, to escape the pull of a planet's gravity.
