Gravitational problem
  1. Aug 31, 2015 #1
    A stationary object is released from a point P at distance 4R from the centre of the earth which has radius R and mas M.What is the speed of the object when it hits the Earth's surfacehttps://scontent-kul1-1.xx.fbcdn.net/hphotos-xpt1/v/t34.0-12/11921921_10204785254702789_1979507807_n.jpg?oh=4a62967277ee876cb2de85befad6b89a&oe=55E68D61
    2. Relevant equations
    Gravitational
    3. The attempt at a solution
    By using the principle of conservational of energy.
    1/2mv^2=-GMm/R-(-GMm/4R)
    which is the final point-initial point
    but the solution is
    1/2mv^2=-GMm/4R-(-GMm/R)
    which is the initial point-final point
    So which 1 is correct i got little bit confused here.Arent we should use the final-initial to find the changes of gravitatinal potential energy?
  3. Aug 31, 2015 #2
    BvU
    2017 Award
    Hello,
    The kinetic energy is positive. Potential energy is negative, so the book solution is correct. The energy balance you want to solve for is:
    ##E_{\rm kin, final } + E_{\rm potential, final} = E_{\rm kin, initial } + E_{\rm potential, initial}## with ## E_{\rm kin, initial } = 0 ##. If you write that out, which one do you get ?
  4. Aug 31, 2015 #3
    Hi, thank you for your explaination :smile:
    another thing that confused me is this question
    The figure below shows a point P which at a distance R from the centre of the Earth, has gravitional potential of -6kJ kg^-1 . What is the change in gravitational potential energy when a 1kg mass is moved from point P to point Q, 2R away from the centre of the earth?
    https://scontent-kul1-1.xx.fbcdn.net/hphotos-xtp1/v/t34.0-12/11922950_10204785470108174_1313158553_n.jpg?oh=f63e57fca18f483818a21a849bed979c&oe=55E67634
    So Gravitational potential energy at point Q is -3kJkg^-1
    The change in gravitational potential energy is P-Q or Q-P. I get really confused here. since the question above use Inital - final, so i should use gravitational in point P- point Q also?
  5. Aug 31, 2015 #4
    BvU
    2017 Award
    Better to write down an expression for the ratio of these energies...
    Sorry, too fast. Does the potential energy become less negative ? That is the same as saying it increases, so the difference is positive.
    And in the question above you did not use initial - final but initial = final. See the expression ##E_{...}##
  6. Aug 31, 2015 #5
    Owh so the second question is using final - initial to find up the change?
    -3-(-6)=+3 ?
    correct me if i did mistake :D
    by the way thanks for answer i truthly appreciate:woot:
  7. Aug 31, 2015 #6
    BvU
    2017 Award
    No need for correction. You are doing fine !
Have something to add?
Draft saved Draft deleted
Similar Discussions: Gravitational problem
  1. Gravitation Problem (Replies: 3)
  2. Gravitational Problem (Replies: 1)
  3. Gravitation problem! (Replies: 4)
  4. Gravitational Problem (Replies: 1)
  5. Gravitation problem (Replies: 6)
Loading...
