Gravitational Speed: Is Removal & Creation Equal?
In summary, gravitational speed is the speed at which objects move due to the force of gravity, and this force is responsible for both the creation and removal of objects in the universe. According to Einstein's theory of general relativity, the speed of gravity is believed to be constant and equal to the speed of light. However, this speed may vary depending on the medium through which the gravitational force is acting. The mass of an object does not directly affect its gravitational speed, but it does determine the strength of its gravitational force. It is not possible for gravitational speed to be faster than the speed of light, but there are theories that suggest otherwise. The curvature of spacetime, as described by Einstein's theory of general relativity, does affect gravitational
sciencecrazy
Is speed of removal of gravitational field (curve) and creation of G.F.(c.) equal?
I want to know if there is any proven or even incomplete theory for it.
Also what is possible speed of gravitation and if there has been some ways of deriving it.
Astronomy news on Phys.org
The 'speed' of gravity comes from GR - and it is 'c'. Beyond that, I don't understand your question.
Basically,
Speed of gravity = speed of light
1. How does gravitational speed affect the creation and removal of objects?
Gravitational speed refers to the speed at which objects move due to the force of gravity. This force is responsible for both the creation and removal of objects in the universe. For example, the force of gravity between two objects can cause them to collide and merge, creating a larger object. On the other hand, the same force can also cause objects to break apart or be pulled into another object, resulting in their removal from their previous location.
2. Is the speed of gravity constant?
According to Einstein's theory of general relativity, the speed of gravity is believed to be equal to the speed of light. This means that it is a constant value of approximately 299,792,458 meters per second in a vacuum. However, this speed can vary depending on the medium through which the gravitational force is acting.
3. How does the mass of an object affect its gravitational speed?
The mass of an object does not directly affect its gravitational speed. However, the mass of an object does determine the strength of its gravitational force. Objects with larger masses will have a stronger gravitational force and therefore may experience a greater gravitational speed as a result.
4. Can gravitational speed be faster than the speed of light?
No, according to our current understanding of physics, it is not possible for any object or force to travel faster than the speed of light. This includes the speed of gravity. However, there are some theories that suggest the existence of particles called "tachyons" which may have the ability to travel faster than light, but this has not been proven.
5. Does the curvature of spacetime affect gravitational speed?
Yes, the curvature of spacetime, as described by Einstein's theory of general relativity, plays a crucial role in the gravitational speed of objects. The greater the curvature of spacetime, the stronger the gravitational force, and therefore the greater the gravitational speed. This is why objects with larger masses have a greater gravitational speed, as their mass causes a greater curvature in spacetime.
  • Astronomy and Astrophysics
