Blistex
- 2
A 4.0m long, 500kg steel beam extends horizontally from where it has been bolted to the framework of a new building under construction. A 70kg construction worker stands at the far end of the beam. What is the magnitude of the torque about the point where the beam is bolted in place?
M1 = 500kg
M2= 570kg
X1 = 0m
X2 = 4m
g = 9.8 m/s2
T = Mgxcm
Where Mg is the net gravitational force on the object and Xcm is the moment arm between the rotational axis and the center of mass.
I thought this problem would quite simple but I think there might be an error in my reasoning.
I start by calculating the center of mass. {(500kg)(0m) + (570kg)(4m)}/1070kg = 2.13m
So the CM is 2.13 from the fulcrum.
Next I substitute the given values into the equation. T = (500kg + 70kg)(9.8m/s2)(2.13m) = 11902NM or 11.9k Nm.
This should be the torque about the fulcrum.
Thanks for the help :tongue: the book says 12.5k Nm. So far it's been pretty spot on this far.
