Gravity and Air Resistance
  • Thread starter Nance
I'm trying to figure out this problem...
A rock of mass 49 kg accidentally breaks loose from the edge of a cliff and falls straight down. The magnitude of the air resistance that opposes its downward motion is 249 N. What is the magnitude of the acceleration of the rock?
I know that I should multiply 49kgx9.8 to figure out the effect gravity has, right?, but I have no idea how to figure in the 249 N air resistance...
Answers and Replies
olgranpappy
1,271
I know that I should multiply 49kgx9.8 to figure out the effect gravity has...
um, sure. of course, the accleration due to gravity will be the same for any object regardless of the mass...
P.S. this forum is not where you post homework questions. there is a specific forum for that.
Draw a free-body diagram and label the two forces that act on the rock.
The force that is exerted on an object of mass m due to gravity near the earth's surface is
F=mg where g = ~9.81m/s^2
Then you have the force of 249N acting in the opposite direction (air resistance). Due to the vector nature of these forces, how can you find the resultant force?
Would I then subtract 249N from F=mg?
Ps, sorry I didn't know questions were supposed to be posted in another forum! In the future, I will post elsewhere! :)
Yes that is correct. You first have a adopt a sign convention. Lets call upwards positive and downwards negative. (when you said would I then subtract 249N from f=mg you were basically calling up negative and downwards positive, it doesn't matter as long as you keep it the same throughout the problem. I prefer to call up positive)
[tex]F_{net}=\Sigma F[/tex]
=[tex]F_{air resistance}+F_{g}[/tex]
=[tex]249 N - 480.69N[/tex](since gravity acts downwards we assign the force a negative value)
=-231.69N or [tex]2.3x10^{2}N[/tex] downwards.
Now use F=ma to calculate the acceleration
Thank you for your help!
Anytime. Good luck.
Related Threads on Gravity and Air Resistance
  • Last Post
C
  • Last Post
  • Last Post
  • Last Post
