B Gravity and expansion
  1. Apr 11, 2017 #1
    If the Universe is expanding, wouldn't it be common sense to think everything inside it is expanding too?
  3. Apr 11, 2017 #2
    No. the space in between objects is expanding but not the objects like earth themselves... This is what you asked, correct?
  4. Apr 11, 2017 #3
    And to add on, this is pretty much just happening at the intergalactic level.
  5. Apr 11, 2017 #4
    If spacetime is expanding then new heres and nows are being created.
  6. Apr 12, 2017 #5
    Drakkith
    Staff Emeritus
    The expansion of the universe is about the distance between objects increasing over time. Note my choice of words there. The distance between objects. Objects bound together by strong forces, such as the atoms in molecules or planets to their stars, are not expanding as far as we know. But, given a large enough distance, these forces drop off far enough to allow expansion to take place and the objects get further away from each other over time.
  7. Apr 12, 2017 #6
    PeterDonis
    Staff: Mentor
    This is not correct. Spacetime is a 4-dimensional manifold; it already contains all "heres" and "nows". "Expanding" just labels a particular feature of the geometry of this 4-dimensional manifold.
    Also, since as far as we can tell spacetime is a continuum, even if we adopt a particular coordinate chart (such as standard FRW coordinates), expansion does not create new "space" in these coordinates. Each "point in space" can be labeled in FRW coordinates and the labels are the same at every instant of time.
  8. Dec 14, 2017 #7
    I have not really understood this. If the space expands, do fields like the electrical field and the gravitational field expand by the same amount? - That would mean that any objects and also galaxies expand in the same way as the space and are so unchanged in relation to the space.
  9. Dec 14, 2017 #8
    It is true, at least according to the dark energy model, that expansion does exert a very small ‘negative pressure’ on objects which causes them to expand more than they would without the pressure from expansion. But the effects are so small I don’t think it’s possible to measure on such small scales. And in any case it’s no where near enough to overcome the forces that hold objects together.
  10. Dec 14, 2017 #9
    I do not mean any pressure or any force.
    If there is for instance relativistic contraction (in SRT) then there is contraction for all objects and for all fields and for everything. There is no force involved. - My question is whether expansion in case of the whole universe is the same or is it different so that the distances of objects expand but fields of any kind do not change.
  11. Dec 14, 2017 #10
    phinds
    No, it would not mean that at all. Again, objects on the order of galactic clusters and smaller do not expand. EM radiation BETWEEN such bound systems does change. Light drops in frequency and loses energy when traveling between bound systems.
  12. Dec 14, 2017 #11
    Interesting discussion. Are you saying that electromagnetic fields inside atoms do not expand but such fields in between galaxy clusters, galaxies, stars perhaps or even planets , do ? At what scale does this transition from expansion to non-expansion occur ?
  13. Dec 14, 2017 #12
    Drakkith
    Staff Emeritus
    The value of the field at any particular point in space will likely change as expansion causes charges to move away from each other, but whether or not that means that the "field itself" is expanding is difficult to answer.
  14. Dec 14, 2017 #13
    PeterDonis
    Staff: Mentor
    Fields don't have a size, so asking whether or not they expand makes no sense.
    Since you are starting from a mistaken premise, you can't expect to reason correctly from it.
    If your question is whether bound systems expand due to the universe's expansion, the answer has already been given in this thread: no.
    For objects, yes. Fields don't have a size so they can't "contract". The components of fields are affected by a Lorentz transformation, yes, just like the components of any vector or tensor.
    No. You're trying to compare apples and haircuts. They're not even the same kind of thing.
    Length contraction is an effect of changing your choice of coordinates.
    Expansion of the universe is a way of describing the overall spacetime geometry of the universe in terms of the behavior of the worldlines of comoving objects.
    The distances between comoving objects increase. That has nothing to do with the behavior of any fields (at least as far as I can tell what you mean by that term; you don't seem to be using it in the usual way).
    There is no "transition". The spacetime geometry of the universe is what it is. Comoving objects have particular worldlines in this geometry. Individual parts of bound systems (like stars in a galaxy or planets in a solar system) have other worldlines. That's all there is to it. You can't pick out regions and say that "expansion" is happening in some but not others. Once you've described all the worldlines of objects and the geometry of spacetime, you've described everything; there's nothing left over.
  15. Dec 15, 2017 #14
    PeroK
    Expansion is only measurable on large scales. If you do the calculation then the expansion between the Earth and Sun is about 10m per
    year.
    The Earth, however, cannot keep drifting further away each year. Instead, gravity and any expansion settle into a stable equilibrium, with expansion slightly reducing the effect of gravity.
    The Earth's orbit, therefore, is slightly larger than it would be if there were no expansion.
    In this case, the solar system is gravitationally bound. Which means gravity is the dominant factor.
    At an intermediate scale - The Milky Way and Andromeda galaxies say - although still gravitationally bound, the effects of expansion would be more noticeable.
    On a larger scale, the gravity between distant galaxies is so small compared to the expansion that gravity becomes negligible and you have effectively only expansion.
  16. Dec 15, 2017 #15
    Bandersnatch
    Looks like you're using Hubble's law for these calculations. I.e. you took the Hubble constant, and calculated the Hubble flow for 1 AU, which over 1 year gives about 10 metres.
    It's not the right way to go about, as you're mixing expansion with acceleration. Expansion by itself (w/o dark energy) is similar to inertial motion, rather than a force - i.e. it can't make Earth's orbit larger. The 10 m/year increase is what you'd get if only if the Earth and the Sun were moving with the Hubble flow. They aren't - they're gravitationally bound. They had long decoupled from the Hubble flow, which has as much bearing on the size of Earth's orbit today as the velocity of gas particles in the molecular cloud from which the Solar system coalesced. There's no equilibrium to talk about with expansion (without DE).
    What does increase the orbit is dark energy, but that's many orders of magnitude less pronounced than what you calculated. At 1 AU it should result in acceleration of something like ##~10^{-25} m/s^2##. Compare with centripetal acceleration in Earth's orbit: ##~10^{-2} m/s^2##.
    So, unless I borked the calculations, that means the orbit is one picometre larger than it'd be without it.
    But again, that's the effect of DE. Without it, the expansion itself wouldn't have any effect.
  17. Dec 15, 2017 #16
    PeroK
    Fair enough, but you then still have to answer the question at which point do you transition from a gravitationally bound system to one where expansion applies.
    How far from the Sun must you be to measure a non-zero recessional red-shift?
  18. Dec 15, 2017 #17
    PeroK
    PS the ##10m## per annum clearly doesn't equate to a ##10m## increase in orbit I could equally well have calculated the hypothetical expansion per second, which would be a fraction of a metre.
  19. Dec 15, 2017 #18
    PeterDonis
    Staff: Mentor
    No, it's very, very, very slightly larger than it would be if there were no dark energy. In an expanding universe with zero dark energy the size of the Earth's orbit would be unaffected by the expansion.
    None of this is correct as regards expansion in the absence of dark energy.
    There is no such "transition". See the last paragraph of my post #13.
  20. Dec 15, 2017 #19
    Yes, fields can contract, and that is (as you say) described by the Lorentz transformation.
    And you can measure the contraction. If you have a charge, then at a distance r from the charge you may have a field strength E. If now the field contracts (by whatever cause) by a factor of 2, then at the position r you will measure a field of E/4. That is a clear indication of the contraction.
    This is particularly visible for multipole fields like the electrical fields in objects. The molecules in an object are bound to each other by electrical multipole fields. The size of the object is mostly given by the extension of these fields. So, if the object contracts in motion (special relativity) then this is only possible because the fields contract. This causes for instance the MM apparatus to contract in motion and that causes, as we know, the null result of that experiment.
    A similar thing happens in a gravitational field. If space contracts which contains a gravitational field, also objects contract there because the binding fields inside contract.
    Now cosmology tells us that the space of the universe expands. That is the opposite to contraction but understood to be fundamentally the same phenomenon like relativistic contraction. And if it is the same phenomenon then the rules and consequences have to be similar. But this would now mean that also gravitational fields expand, and so the size of planetary orbits has to increase and also the size of galaxies, as the constituents of a galaxy are bound gravitationally to each other.
    So the assumption that the distance of galaxies (which are maintained by inertia and so fixed to the space) on the one hand and the size of galaxies on the other hand behave differently (as some has said in this discussion) does not look logical.
  21. Dec 15, 2017 #20
    PeterDonis
    Staff: Mentor
    Please give a reference for the experimental results that demonstrate this.
    Please note that I am not disputing that electromagnetism is consistent with SR; of course it is. I am asking for a specific experimental situation that merits the description "the field contracts" as you have described it, in order to justify the further claims you are making.
    Same comment here: please give a reference for the specific experimental results that demonstrate this.
    No, it doesn't. That is pop science, not real science. Real cosmology tells us that comoving objects in our universe are moving apart. That is not the same as "space expands".
    No, it isn't. It has nothing to do with length contraction in SR.
    The rest of your post just builds on these misconceptions.
