Gravity? Did he fall or was he pushed?
In summary, General Relativity (GR) states that what we think of as the "force" of gravity is really just a result of the curvature of spacetime.
Devilin
39
A. relatively simple question, is gravity a pulling force or a pushing force, or both?
Good question - some years ago there was a website that posed the same question and offered some interesting insight - but perhaps it can't really be said to be one or the other - In GR mass conditions spacetime - so another mass feels the gradient (the conditioning brought about by the first mass). Here is another thought - consider a mass in free space that will experience an inertial force when accelerated in any direction - there appears to be a uniform isotropic inertial field that exists throughout the cosmos - now introduce a second mass nearby - when the first mass is accelerated toward the second at a rate equal to the gravitatinal attraction - no force is experienced - if the acceleration is greater than the g force - there will be some inertial reactionary force - but it will be less, etc - so what has happened - the second mass has unbalanced the uniform isotropic inertial field
There is a pushing gravity "theory" (in quotes because despite the claims of its proponents, it is NOT a theory). One big problem is there should be no gravity inside your house.
Devilin, the answer is: Neither. It is not a push or a pull, because there is no such thing as force. Before you right me off as a kook, I should explain. You see, Einstein postulated General Relativity, and it is the currently accepted theory of gravity (though some do disagree). In General Relativity (GR), what we think of as the "force" of gravity is really just a result of the curvature of spacetime.
In case you haven't heard of anything like this before, I'll post an analogy: Imagine a two-dimensional "flat man", who lives his life out on a piece of paper (which will represent the Universe altogether). Now, let's say that I (three-dimensional God) bend the piece of paper, right in front of where the flat man was about to walk. Obviously, he would move in a "crooked" path, due to the bent nature of the space he's walking on, but as far as he's concerned there must be a force that is either pushing or pulling him to move in that direction.
Does that make sense?
Actually...No, it doesn't because the flat man would have NO depth perception, therefore he would not perceive any force holding him to anything that hadn't already/always been there.
(He wouldn't perceive the bend!)
As for Push or Pull force, 3D guys, all energetic activities, from/in nature, are either expansive, or contractive, of space.
EDIT SP!
(uniform isotropic inertial field) you've got me there, I've got no idea what your talking about?, could you explain in little words with few syllables? pls :)
As for the space time depression, that was my premise for asking the question, as although gravity itself, its a theoretical and dubious matter, excuse the pun, a submarine when submerged, has the force exerted from the outside pushing inward, wouldn't this Principal be exactly the same in space time itself? and the reason you wouldn't float in zero gee in your house, is the dent in space time, would be a multi dimensional affair,? could gravity be a dimension? Like time or space?
Assuming of course there's no little gravity particles flying around, because of course if there was, Newton's law would mean there's anti gravity particles flying around as well, unless you use this theory for the increasing expansion of the universe itself
Or maybe I'm just talking rubbish? Enlightened me please
Devilin: Perhaps it would help if you gave a PRECISE definition of the "Push" and "Pull".
Devlin - when I refer to a uniform isotropic inertial field - it is simply a way of describing the experimental fact that wherever a mass is located - it experiences the same inertial reaction no matter in which direction it is accelerated (isotropic) - whatever it is that produces inertia, it appears to have the same value throughout the universe (uniform) - but that all gets modified in the presense of a second mass - whatever the nature of the field - it gets modified by other matter - the proverbeal concept of a field is that it has properties associated with different locations - Einstein renamed the either spacetime - and he asserted that this spacetime gets conditioned by the presence of other material bodies that exhibit mass-energy. (Does that help).
Personally I've always assumed, that a object if containing enough mass would pull other objects towards it, the mass itself being the pulling object, although now I've reached a uneasy conclusion that the mass of a object, purchase space time onto a object
yogi thanks, if my tiny brain has perceived this correctly, which I seriously doubt it has, I'll need to think on this and I assumed isotropic was a form of energy drink
No, gravity is not a perceived state, it is a real state, and although the word force might not be a appropriate word, there is definitely something forcing ( pulling/pushing) me towards the ground, and although I assume this is a result of the curvature of spacetime. a action, or reaction ( force ) is definitely present, Does that make sense?
I'd say gravity is a pulling interaction, although in relation to things with NEGATIVE mass/energy it might act as a pushing one.
Standing on the surface of the Earth and being accelerated in 9.8 G's in a weightless environment feels like the same thing. Logically, this must mean that when you fall towards Earth, let's say from an airplane, you are not feeling any acceleration at all. But you're moving, and picking up speed, still you're not really being accelerated. What's happening here? :)
What is happening is Einstein's equivalence principle which means an inetrial refernce frame due to gravity is the same as an inertial frame due to accelration which means that all frames are relative as long as you include the correct gravitational field.
1. What is gravity?
Gravity is a force that exists between any two objects with mass. It is responsible for keeping objects in orbit around each other and for the formation of planets, stars, and galaxies.
2. How does gravity work?
Gravity works by pulling objects towards each other. The strength of the gravitational force between two objects depends on their masses and the distance between them.
3. Why do we experience gravity on Earth?
We experience gravity on Earth because our planet has a large mass, which creates a strong gravitational force. This force pulls us towards the center of the Earth, keeping us on the surface.
4. Is gravity the same everywhere in the universe?
No, gravity is not the same everywhere in the universe. The strength of gravity depends on the mass and distance of objects, so it can vary in different parts of the universe.
5. Did gravity always exist?
As far as we know, yes, gravity has always existed. It is one of the four fundamental forces of nature and has been present since the beginning of the universe.
  • Mechanics
  • Mechanics
  • Mechanics
