Homework Help: Gravity (Kinematics)
  1. Jan 27, 2008 #1
    The acceleration of gravity can be measured by project a body upward and measuring the time that it takes to pass two given points in both directions. Show that if the time the body takes to pass a horizontal line A in both directions is Ta and the time to go by a second line B in both directions is Tb then assuming that the acceleration is constant, its magnitude is g = 8h/(Ta^2-Tb^2)
    2. Relevant equations
    y = y0 + 1/2 g t^2 + vot
    3. The attempt at a solution
    There is a diagram where A is the lower position and B is the higher position, they are separated by a distance h.
    I found Ta = -2/g vy and Tb = -vy +- sqrt(vy^2 - 2gh)
    but I really don't know where to go after this...
    If I want acceleration a = dv/dt and v = dx/dt but I'm not quite sure what to do next... If I say delta T = Ta - Tb but that's all i can get.
  3. Jan 28, 2008 #2
    mezarashi
    You'll need 2 equations to solve this problem:
    1. Express the initial velocities Va and Vb as a function f(g,ta) and f(g,tb) respectively. This can be done using the s = vt + 0.5at^2 kinematics equation.
    2. Use the kinematics equation: Vb^2 = Va^2 + 2gh
    From equation 2, you can substitute out Vb and Va into a function purely of g and t. From there, it's just algebra. Good luck.
Loading...
