Gravity of the Earth decreases if it stops spinning?
  • B
  • Thread starter aiop
  • #76
63
Another point I need to make:The Earth's bulge is NOT due to the current very very weak centrifugal force. The entire earth was once moltent and spinning much more rapidly before the moon existed, carring much of the original angular monementum away from the earth. The Earth's bulge when its surface solified, was larger than now, and is still adjusting (becoming less). I. e. it is NOT yet back to an equlibrium bulge. Many 100s of thousands of year from now, we still will have more bulge than the current very very weak centrifugal force would make.
Again I note: The current centrifugal force is the same as an 8000+ mile diameter merry-go-round turning very very slowly* would have at its edge.
* One turn takes 24 hours!
  • #77
63
It isn't a perfect sphere.
If the container is spherical and with unform wall thickness then at its center, or anywhwere inside, there is no "micro-gravity" from the container mass. Make container orbit / drift in space at least a 1000AU from the sun* and as it has opaque copper walls, with small amount of decaying isotope in the copper, so even in deep space the temperature inside is more than 0C and with no gradients; Then there is no sunlight pressure on one side of the drop and no convection air currents to distort it.
* The container is in "free fall" with path very slightly influenced by sun and other cosmic masses but that path removes all gravity effects from remote objects. Also the inside walls are "hydrophobic," so even if the small water drop should briefly touch a wall, it is repelled and becomes spherical immediately again.
Why would the drop not be a perfect sphere?
  • #78
A.T.
2,315
What does "more" mean? How many km more? According to
https://en.wikipedia.org/wiki/Geoid
the equipotential surface (based on current centrifugal potential) deviates only −106 to +85 m from the reference Ellipsoid with a 21km radius difference (current Earth shape approximation).
  • #79
A.T.
2,315
Because it’s made of molecules.
  • #80
63
@mfb: I am still waiting for you to demonstrate that the contraction at equator with removal of centrfugal force is large compared to the expansion due to a large mass of water going towards the poles (less compressive force). Or, like my opposite belief, just admit that is ONLY your belief too?
  • #81
63
ok. I admit it is only on the stastical average spherical, but at any time will have a surface roughness of a few atomic diameters.
However, if you have chosen the total number of molecules correctly and the drop is very small and at 1C, then the surface roughness can be less about the diameter of an oxygen atom.
As H2O is a polar molecule with both Hs on the same side, 105 degrees apart, regular stable 3D structures do form that are almost spherical, in the conditions I have described.
  • #82
63
I don't know how many Km of adjustment from the shape the molten, much more rapidly spining earth took when it solified, still remains to be made. Your reference is not fully correct - even a non-spinning ocean covered earth without any exposed land mass would not have oceans in an equal gravitational potential because there are thermally driven ocean currents (They would be much larger flows if the earth were not spinning.)
I worked 30 years at APL/JHU where we made the first orbiting radar altimeter with a precision of about 1 cm. It could see the gulf stream. The Coriolis force on the North flowing gulf steam pushes it eastward. That makes the east edge about a meter higher that the west edge as the GS water is forced into the non-flowing water on its east side.
  • #83
anorlunda
Staff Emeritus
Insights Author
8,875
5,783
The Earth as a whole is quite liquid. It even has tides.
Oh wow, I never thought of that. Do I read you correctly that the crust (not just the oceans) have measurable lunar tidal distortions.
Without rotation, the equatorial bulge would vanish over time, leading to some really nasty earthquakes and to a spherical shape of Earth. Once that shape has been reached, the water will be distributed over the whole surface again.
But what about plate tectonics? Wouldn't that still create mid-ocean ridges and continents independent of tidal forces? Of course that depends on the time scale since eventually the center of the planet will freeze and all internal motion will stop.
  • #84
A.T.
2,315
Then how do you know it's even relevant, compared to the ~21km radius difference? You are just going off on tangents about irrelevant details.
  • #85
34,968
11,156
@mfb: can you demonstrate that the contraction at equator with removal of centrfugal force is large compared to the expansion due to a large mass of water going towards the poles (less compressive force). Or, like my opposite belief, that is just your belief?
I did so already. Compare the mass of 20 km of rock to the mass of ~3 km of water. The rock wins by a factor of about 20.
It is. Compare the shape to the geoid.
The continental plates are constantly moving around - plates that are now at the equator were once at the poles and vice versa, multiple times over the last billion years. Earth is not a solid object. It is a liquid with a few shallow blocks of solid matter on top that follow the flow of the liquid interior.
And we are back at meter-sized effects while you keep ignoring the 20 kilometer effect.
I'm sorry for not being available 24/7 to answer your questions. No wait, I am not. I also do physics to earn money, and that has priority (together with sleep, I'm from Europe and your question was at 1:20 am here).
Yes. And the LHC has to take this into account to get the beams around the ring. Story about it
You still get seas and land masses as today, of course, but their height is small compared to the effect we are talking about. It is also much more local.
  • #86
ogg
148
35
Wow. Seems to me this tread has jumped the shark. The OP asked about centripital forces and gravitational forces and we're now talking about variations in the g field (not "G"!!) due to variations in matter density, temperature, and fluid flow. I mean, really? There's also the claim that centripital force has "nothing" to do with gravitational force. Really? I thought acceleration was "indistinguishable" from a g-field. The FACT is that they DO have something in common (obviously) - although you might argue that their similarities are outside the realm of classical physics...or that discussing their similarities will involve issues of (2nd order) differentials.
Related Threads on Gravity of the Earth decreases if it stops spinning?
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
9K
  • Last Post
  • Last Post
  • Last Post
