• Support PF! Buy your school textbooks, materials and every day products Here!
Gravity Pulling Blocks
  • Thread starter anastasiaw
So for the block m1, m1a=T-m1gsin25-/mu*m1gcos25. And that is solving for? The net force right?
Forces acting on m2 would be gravity pulling down, tension pulling up. And that's it right?
rock.freak667
6,230
31
Yes but you don't know the value of T just yet.
Yes that is right, so m2a= ?, now when you get this equation, you can find T and then out that into the first equation to get m1
so m2a=m2g-T
Then go through and do the math and T= 47.32.
Then I plug that in for T in the m1a=T-m1g*sin25-/mu*m1g*cos25
But how would I go about isolating m1?
rock.freak667
6,230
31
so m2a=m2g-T
Well you would just need to calculate the constants and then rearrange. a=3.05, you can calculate gsin25° and μgcos25°
So you'd have something like
Am1=47.32-Bm1-Cm1
Where A,B and C are constants.
You get all the terms with m1 in them to one side of the equation and factor the m1 out.
  • #31
...If I divide out the m1 in order to get it to one side, won't that cancel out all the m1's?
  • #32
346
You can't divide out because there is no m1 term in front of the T. That is why you have to get all the m1 terms on the same side and pull the common term (i.e. m1).
  • #33
rock.freak667
6,230
31
No, the value of 'T' has no m1 in it. Just gather the like terms on side and then divide.
  • #34
When I go through and divide everything out, I get 6.99kg... That doesn't seem possible?
And isn't the correct answer...
  • #35
I went through and re-worked it. Got 4.472kg which is the correct answer. Thank you sooooo much Rockfreak. You have been an invaluable resource on this matter.
Related Threads on Gravity Pulling Blocks
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
