Acceleration w/o Velocity Change: Gravity Ques
In summary: Gravity, GmM/r^2, no dv's in that one... it exists without anything changing velocity?Yes, Gravity exists without any change in velocity.Gravity, GmM/r^2, no dv's in that one... it exists without anything changing velocity?6.67 × 10-11 m3kg-1s-2 ... what do those units even...???They are meters per second squared.They are meters per second squared.
JLT
52
If acceleration involves a change in velocity - dv/dt, what velocity is changing for an object at rest with gravitational force? Example - an apple on a table, mg down = the normal force ma up, but neither a nor g seem to involve a dv? the forces involved do not involve changing any velocities, and yet there are still accelerations there... so what is acceleration if there are no (V2-V1)/(t2-t1)'s going on? Did that make sense?
JLT said:
the forces involved do not involve changing any velocities, and yet there are still accelerations there... so what is acceleration if not dV?
What do you mean? What is accelerating in your example of an apple sitting on a table?
Draw the FBD of it - there are forces in static systems. F = ma, there are "a"'s in static systems, even without any dv's.
As you said, acceleration is defined as the change in velocity over the change in time: ##a=\frac{dv}{dt}##
If you substitute this into the force equation you can see that ##dv## is indeed present and is zero in the case of balanced forces.
example; F=kx=ma is not zero, a = kx/m, a positive value even though dv/dt = 0 if the system is in equilibrium. It just seems like there is some other acceleration going on, or some other way to think of it - were a is not dv/dt in all cases?
The F in F=ma is the net force on an object unless you're explicitly breaking force and acceleration down into their different components. So you can certainly calculate that the force from a spring should give an acceleration to a block, but unless you account for all the forces acting on the block then you're doing things wrong.
F is the net force. It is 0 in your example.
let's say we are breaking the net force up, and just looking at each individual component. we call each component a force, it could be mg, or uN or kx or F=kq1q2/r^2, or whatever the case may be. If you let go of the system each of those individual forces can turn into a change in velocity for something, but it does not have to change the velocity of something to be considered a force. You can squeeze an apple, and squeeze it more and more with larger and larger forces without changing the position or velocity of the apple - forces have changed, the velocity has not changed. Is force not always equal to ma? not always equal to mdv/dt?
So the "net" force is always ma, but the individual components of the forces are not equal to ma?
Correct.
Dale said:
Correct.
kg m/s^2... if the individual component is not mdv/dt, then what is it?
It is a force. Why should it be anything else.
Dale said:
It is a force.
I guess I'm having a hard time understanding what a force really is if it does not have to involve dv.
Thanks for all the replies!
You can think of pressure as being momentum flux. Then force is the integral of the momentum flux over a surface. Force is then just an idealization of momentum flux when you are not interested in the details of the surface.
But I don't think that is helpful.
pressure involves a bunch of dv's, I can visualize that one...
but gravity, GmM/r^2, no dv's in that one... it exists without anything changing velocity? What is the physical sig of G? 6.67 × 10-11 m3kg-1s-2 ... what do those units even mean?
JLT said:
pressure involves a bunch of dv's.
Not in general. Fields exert pressure even without any "dv"s. Not everything is a gas
Looking for what something "really is" usually just leads to confusion. Force is the thing which behaves as described by Newton's laws. If there are no forces the acceleration is 0. Forces are vectors quantities that can be added together and if you add up all the forces acting on an object then they are equal to the mass times the acceleration of the center of mass. And when an object exerts a force on another object then the other object also exerts an equal and opposite force on the first object. That is what force really is.
Likes Drakkith
Dale said:
Looking for what something "really is" usually just leads to confusion. .
So science only describes interactions, but never actually explains the thing itself? We'll always be standing on the outside looking at the surface of things? That's disappointing...
Likes PeroK
Sorry that you are disappointed, but it isn't too bad. If you could predict how a person would behave in every interaction then you would probably feel like you know them very well, even if it is all from the outside looking at the surface.
Knowing "how/what" is different than knowing "why"... without knowing the why's it doesn't feel like knowing much. Thanks again.
You can't ever "really explain" anything. Every explanation you come up with will generate a new question needing a new explanation. For example, mankind spent millennia looking for an explanation of the motion of the planets in the night sky before Copernicus, Galileo, Kepler, and Newton figured it out: the planets are bodies orbiting the sun, the Earth is one of those bodies, and the force between them is given by Newton's ##F=Gm_1m_2/r^2##. Now that is a truly great explanation, and I cannot imagine anyone being even slightly disappointed by it.
But have "really explained" planetary motion? No. We just have a new problem, namely explaining why the force is given by that formula and not some other. Why ##r^2## instead of, for example, ##r^3##? Eventually we have to end up with something for which the only explanation is "because that's the way the universe we live in works".
The aim of physics is to make quantitative predictions, not to make you feel knowledgeable.
Likes malawi_glenn, Dale and weirdoguy
OK, then you probably should study religion or philosophy instead of science. Science is not designed to answer "why" questions, except with a theory that is, in the end, an answer to a more general "how/what" question. Both religion and philosophy are much better suited to answering "why" questions.
Likes malawi_glenn
Even with religion, one question leads to another. If God created the universe, why wasn't one solar system enough?
Likes malawi_glenn
haha
Because variety is the spice of life :biggrin:sorry, couldn't resist
Haha - didn't mean to take this into a philosophical route, just trying to better understand what a force is. ... Force is something you cannot really see, cannot measure with a ruler, is not always mdv/dt - I guess you have to just "feel" it - so we can all close our eyes, hold hands, and "feel the force", feel the floor pushing against our feet, and feel gravity pulling down on our gut, feel the air pushing into our lungs - force is some subjective/philosophical/religious/touchy-feely kind of a thing - is that what everyone is trying to say here?
I'm not trying to be a scientist or a preacher here... I'll go with option #3, engineering. Engineering is a little of everything - trying to understand people and their problems, and then solving those problems in tangible ways.
ok, I'll go spend some time getting in touch with my inner feelings, and then let everyone know if I finally figure out what a force is.
you have been told what a force is.
but you wanted to know why and you were told that isn't what physics answers
Force is scientifically well defined through Newton's laws and experiments. The philosophical/religious thing is the question "why". Science simply doesn't answer that kind of question.
Dale said:
Force is scientifically well defined through Newton's laws. The philosophical/religious thing is the question "why". Science simply doesn't answer that kind of question.
Cause / effect = why. The trouble is there is some infinite cause/effect loop with no ultimate beginning to trace it all back to. You can always ask "but why did that happen?" one more time.
It feels like being in one of those movies with a twist ending - going through calculations with all the current available information you have, only you know there's going to be some new piece of information that changes everything around that next corner, and there will always be that next corner...
At this point, don't worry about that. Just focus for now on learning how to apply Newton's laws correctly. For instance, do you now understand that the F in Newton's 2nd law refers to the net force? Do you similarly know what the a refers to (particularly for non rigid motion)?
Likes JLT
Newtons Laws are sometimes informally stated in terms of cause/effect, but formally they just state a quantitative relationship between simultaneous values. In the 2nd Law the force is not a cause, that comes before the effect of acceleration. In the 3rd Law the action is not a cause that comes before the equal but opposite reaction. It all happens at the same time, so the cause/effect attribution is arbitrary.
Don't get confused by informal language. Stick to what the math says.
Likes JLT, Nugatory and Dale
1. What is acceleration without velocity change?
Acceleration without velocity change, also known as free fall or free fall acceleration, is the acceleration of an object due to the force of gravity. It occurs when an object is falling towards the ground without any other forces acting on it.
2. How is acceleration without velocity change related to gravity?
Acceleration without velocity change is directly related to the force of gravity. The acceleration of an object in free fall is equal to the acceleration due to gravity, which is approximately 9.8 meters per second squared on Earth.
3. Can acceleration without velocity change occur in other environments besides Earth?
Yes, acceleration without velocity change can occur in any environment where there is a significant gravitational force acting on an object. This includes other planets, moons, and even in space near large objects like stars or black holes.
4. How does air resistance affect acceleration without velocity change?
Air resistance can affect the acceleration of an object in free fall by slowing it down. This is because air resistance is a force that acts in the opposite direction of the object's motion, causing it to experience a drag force that reduces its acceleration towards the ground.
5. What is the formula for calculating acceleration without velocity change?
The formula for calculating acceleration without velocity change is a = g, where "a" is the acceleration and "g" is the acceleration due to gravity. This formula applies to objects in free fall, where there are no other forces acting on the object besides gravity.
  • Other Physics Topics
