Calculating Work for Satellite Orbits Around Earth
In summary, the work done to put the satellite into circular orbit at a height of 9.29x10^6 m above the surface of the Earth is 2.386E10 Joules. For the second problem, the minimum work needed to move the satellite outward and put it in circular orbit at a new height of 6.05x10^6 m above the surface of the Earth is 3.6123E9 Joules. And for the third problem, the work done to put the satellite into circular orbit at a height of 9.29x10^6 m above the surface of the Earth is 105.69 N.
cobrasny
A satellite mass 481 is in circular orbit of 9.29x10^6 m above the surface of the Earth
the weight of a 65.1 kg astronaut inside the satellite
What work was done (ignoring friction) to put the satellite into this orbit. Assume it started at rest on the surface of the Earth
Also, A satellite of mass 730 kg is in circular orbit around the Earth, 3.12x10^6 m above the surface of the Earth. Find the minimum work needed to move the satellite outward and put it in circular orbit at a new height of 6.05x10^6 m above the surface of the Earth
U = -GMm/r
fg = GMem/r^2
For the first problem, I tried fg = GMem/r^2, (6.67x10^-11) x (5.97x10^24) x 65.1 / (9.29 x 10^6 + 6.371 x 10^6)^2 and got 105.69 N
For the second, U = -GMm/r; W = Ui-Uf
- (6.67x10^-11) x (5.97x10^24) x 481 / (6.371 x 10^6) - (- (6.67x10^-11) x (5.97x10^24) x 65.1 / (9.29 x 10^6 + 6.371 x 10^6) = -1.78E10 Should the work be negative? Is that the work done by gravity, so the work done to move the satellite is the same magnitude, opposite sign?
I tried a similar strategy for the third problem, and it did not work there either.
Hopefully you can help me understand what I am doing wrong. Thanks in advance.
U = -GMm/r
fg = GMem/r^2
Hi cobrasny! :smile:
Hint: for a circular orbit, the work done is the change in U plus the change in KE. :wink:
So..
- (6.67x10^-11) x (5.97x10^24) x 481 / (9.29 x 10^6 + 6.371 x 10^6) - (- (6.67x10^-11) x (5.97x10^24) x 481 / (6.371 x 10^6) = 1.78E10
is just the change in potential energy.
The change in kinetic energy, 1/2mv^2;
v^2 = GMe/r
Re = 6.371x10^6
v=2pi r/T
Vsurface = 2pi 6.371x10^6/(24hrx60minx60sec)
1/2m (vf^2-vi^2)...
.5 (481) [((6.67x10^-11) x (5.97x10^24) / (9.29 x 10^6 + 6.371 x 10^6)) - (2pi 6.371x10^6/ (24x3600))^2] = 6.063E9
Do I then add the change in Ek and change in Eu? To get 1.78E10 + 6.063E9 = 2.386E10 Joules of work?
All right, that worked for the second problem.
Two to go:
Delta U = - (6.67x10^-11) x (5.97x10^24) x 730 / (6.05 x 10^6 + 6.371 x 10^6) - (- (6.67x10^-11) x (5.97x10^24) x 730 / (3.12 x 10^6 + 6.371 x 10^6) = 7.2247E9
delta k = .5 (730) [((6.67x10^-11) x (5.97x10^24) / (6.05 x 10^6 + 6.371 x 10^6)) - ((6.67x10^-11) x (5.97x10^24) / (3.12 x 10^6 + 6.371 x 10^6))] = -3.6124E9
So work done = 7.2247E9 + -3.6124E9 = 3.6123E9 Joules (if you could check this I would appreciate it)
I still don't see what I did wrong here.
1. How is work calculated for satellite orbits around Earth?
The work done on a satellite in orbit around Earth is calculated using the equation W = Fd, where W is work, F is the applied force, and d is the distance traveled by the satellite. This equation takes into account the gravitational force exerted by Earth on the satellite, as well as the distance the satellite travels in its orbit.
2. What units are used to measure work in satellite orbits?
The SI unit for work is the joule (J). In the context of satellite orbits around Earth, work is typically measured in megajoules (MJ) or gigajoules (GJ) due to the large amount of energy involved.
3. How does the mass of the satellite affect the work calculation?
The mass of the satellite does not directly affect the work calculation, as it cancels out in the equation W = Fd. However, a heavier satellite may require more energy to be launched into orbit, resulting in a higher overall work done.
4. What factors can impact the work done on a satellite in orbit?
The main factors that can impact the work done on a satellite in orbit around Earth include the gravitational force exerted by Earth, the distance the satellite travels in its orbit, and any external forces acting on the satellite, such as atmospheric drag or collisions with debris.
5. Is there a way to reduce the work required for a satellite in orbit around Earth?
Yes, there are a few ways to reduce the work required for a satellite in orbit around Earth. One way is to launch the satellite into a lower orbit, where the gravitational force is weaker and the distance traveled is shorter. Another way is to use orbital maneuvers and gravitational assists to minimize the amount of work needed to maintain the satellite's orbit.
