Understanding Work Calculation for Gray Tin Transformation to White Tin
In summary, the pressure obviously changes, and the densities can be looked up. But I have no idea how to attack this beyond that.
RPI_Quantum
50
This is a thermodynamical question:
If Gray tin is isothermally transformed to white tin, how would the work done be calculated? The pressure obviously changes, and the densities can be looked up. But I have no idea how to attack this beyond that.
"The pressure obviously changes" is based on what information given in the original problem statement?
How is mechanical work calculated? Calculate this work the same way, integrate PdV.
Well I know that I should integrate PdV. All that is given in the problem is that white tin transforms to gray tin at a constant temperature of 25 C. The densities of gray and white are the only additional information provided.
I do not know the expression for P to integrate.
You walk into the lab. You set up an experiment on the bench, in the hood, or elsewhere. You heat things, you cool things, you boil them in molten salt and quench them in boiling oil. How often do you have to wear a pressure suit, or climb into a diving bell to do the work?
One atmosphere do ya?
The problem statement says "isothermal." You've been taken through the Gibbs Phase Rule? Degrees of freedom equals number of components (one, Sn), minus number of phases (two, white and grey), plus two; you have one degree of freedom, temperature, and it's been fixed with the isothermal statement. P has to be constant, or you've moved the transition temperature.
Hitting you with a problem like this without GPR first is asking a bit much.
Yeah, okay I'm an idiot... Of course I've seen the phase rule, I just was not looking at the problem carefully. I guess that somewhere in the back of my head I was thinking constant pressure made this too simple of a problem.
Thanks for allowing me to realize my stupidity.
Don't flog yourself. If that's the biggest mistake you ever make in your life, you will have set a new record high score in the human endeavor to achieve perfection.
Of course! I will just laugh at myself in this situation and look back on it when I am 3/4 through this semester of advance thermo. It's just funny that I chose to mess up the easy stuff. I think it is a habit with me!
Just a little background from Webelements -
Ordinary tin is a silvery-white metal, is malleable, somewhat ductile, and has a highly crystalline structure. Due to the breaking of these crystals, a "tin cry" is heard when a bar is bent. The element has two allotropic forms. On warming, grey, or a-tin, with a cubic structure, changes at 13.2°C into white, or b-tin, the ordinary form of the metal. White tin has a tetragonal structure. When tin is cooled below 13.2°C, it changes slowly from white to grey. This change is affected by impurities such as aluminium and zinc, and can be prevented by small additions of antimony or bismuth.
What is Gray Tin Transformation?
Gray Tin Transformation is the process by which tin, a metallic element, transforms from its stable, silver-colored form (white tin) to a brittle, gray-colored form (gray tin) at temperatures below 13.2°C.
Why does tin undergo Gray Tin Transformation?
This transformation occurs due to a change in the crystal structure of the tin atoms. White tin has a tetragonal crystal structure, while gray tin has a cubic crystal structure. As the temperature decreases, the tin atoms rearrange themselves into the more stable cubic structure, resulting in the transformation from white tin to gray tin.
What are the properties of gray tin?
Gray tin is a brittle, gray-colored substance with a density of 5.77 g/cm3. It is a semiconductor and has a lower melting point than white tin. It is also non-malleable and non-ductile, meaning it cannot be easily shaped or stretched.
Is Gray Tin Transformation reversible?
Yes, the transformation from white tin to gray tin and back again is reversible. As the temperature increases above 13.2°C, gray tin will transform back into white tin. This is why tin objects, such as tin cans, do not undergo this transformation at room temperature.
What are the applications of Gray Tin Transformation?
The transformation of tin from white to gray is used as a temperature indicator in some alloys. It is also used in the production of pewter, a mixture of tin, copper, and antimony, which has a lower melting point due to the presence of gray tin. Gray tin is also being studied for potential applications in electronic devices due to its unique properties as a semiconductor.
  • Atomic and Condensed Matter
  • Computing and Technology
  • General Engineering
  • Electrical Engineering
  • Materials and Chemical Engineering
  • DIY Projects
  • Mechanical Engineering
