GrayScott Model
  1. Apr 23, 2017 #1
    Dear Community,
    I was trying to reproduce the 2D GrayScott model given either here: http://blogs.mathworks.com/graphics/2015/03/16/how-the-tiger-got-its-stripes/
    or here: http://www.joakimlinde.se/java/ReactionDiffusion/index.php?size=0
    The reason was to create a nice screen-saver (so I am not really interested in the mathematics behind). So I tried to use matlab for a first trial however my interpretation of the given matlab code (first URL) neither gives results as shown in both the urls. I would be very happy if someone could check the following code – maybe I just forget something important:
    function [t, A, B] = initial_conditions(n)
    t = 0;
    % Initialize A to one
    A = zeros(n); %ones(n);
    % Initialize B to zero which a clump of ones
    B = zeros(n);
    B(50:80 ,50:80) =10;
    % A(50:80 ,50:80) =6;
    %B(61:80,71:80) = 20;
    % --- Executes on button press in pushbutton1.
    function pushbutton1_Callback(hObject, eventdata, handles)
    figure;
    width = 128;
    [t, A, B] = initial_conditions(width);
    % Setup image
    ih=imagesc(B);
    set(ih,'cdatamapping','direct')
    %colormap(hot);
    axis image off;
    th=title('');
    set(gcf,'position',[80 70 512 512],'color',[1 1 1],'menubar','none')
    % Create 'Quit' pushbutton in figure window
    uicontrol('units','normal','position',[.45 .02 .13 .07], ...
    'callback','set(gcf,''userdata'',1)',...
    'fontsize',10,'string','Quit');
    f=.55;
    k=.062;
    da = 1;
    db = 0.1;
    dt = .001;
    done = 0;
    count = 0;
    while ~done
    % anew = A + (da*my_laplacian(A) - A.*B.^2 + f*(1-A))*dt;
    % bnew = B + (db*my_laplacian(B) + A.*B.^2 - (k+f)*B)*dt;
    %dAdt= A + (da*del2(A) - A.*B.^2 + f*(1-A))*dt;
    % dbBdt= B + (db*del2(B) + A.*B.^2 - (k+f)*B)*dt;
    dAdt = da*del2(A) - A.*B.*B + f*(1-A);
    dBdt= db*del2(B) + A.*B.*B - (k+f)*B;%- k*B;
    B = B + dBdt*dt;
    A = A + dAdt*dt;
    % avoid overflow
    if A > 1000
    done = 1;
    A(60,60)
    'over'
    end
    if A < 5.5000e-005
    done = 1;
    A(60,60)
    'over'
    end
    if(mod(count,50) == 40)
    set(ih,'cdata',A); %,B);
    set(th,'string',sprintf('%d %0.2f %0.2f',count,A(60,60),B(60,60)));
    drawnow;
    end;
    count = count + 1;
    if ~isempty(get(gcf,'userdata')), done=1;
    end % Quit if user clicks on 'Quit' button.
    end
  3. Apr 28, 2017 #2
    Mike's blog gives the code. Why not just use his code?
  4. Apr 28, 2017 #3
    Dear Community,
    after try- and error-ing a while I finally found a suitable set of parameters which define the most fascinating manifestation of the GrayScott model: The self replicating spots- simulation. However since it takes a lot of calculation this approach is not well suited for my initial goal to make a screen saver out of it– however if someone else likes to experiment himself a little bit – here is a working code snipped (copied from here and there - majorly from Mikes Blog).
    t = 0;
    A = ones(n);
    B = zeros(n);
    B(51:60 ,51:70) = 1;
    B(61:80,71:80) = 1;
    function out = my_laplacian(in)
    out = -in ...
    + .20*(circshift(in,[ 1, 0]) + circshift(in,[-1, 0]) ...
    + circshift(in,[ 0, 1]) + circshift(in,[ 0,-1])) ...
    + .05*(circshift(in,[ 1, 1]) + circshift(in,[-1, 1]) ...
    + circshift(in,[-1,-1]) + circshift(in,[ 1,-1]));
    f = 0.02;
    k = 0.079;
    % Diffusion rates
    da = 1;
    db = 0.4;%0.5;%.5;
    % Size of grid
    width = 128;
    dt = .25; %.15
    figure;
    % Setup image
    ih=imagesc(B);
    %colormap(hot);
    axis image off;
    th=title('');
    % Add a text object to show the current time.
    ht = text(3,width-3,'Time = 0');
    ht.Color = [.95 .2 .8];
    done = 0;
    %count = 0;
    while ~done
    bnew = B + (db*my_laplacian(B) + A.*B.^2 - k*B) *dt; %;- (k+f)*B)*dt;
    A = anew;
    B = bnew;
    t = t+dt;
    if(mod(count,100) == 40)
    set(ih,'cdata',B.*30); %,B); %multiplying B with a factor was important for visualization
    drawnow;
    end;
    % count = count + 1;
    end
    @ Image analyst: I certainly tried Mikes code but using my old Matlab 6.5 there were no waves visible (probably because ‘image’ has no autoscale feature). Furthermore I wanted ‘Selfreplicating spots’ shown on Joakim Lindes’ page ( – however without Mikes great Blog I wouldn’t be able to run a GrayScott model myself).
Have something to add?
Draft saved Draft deleted
Loading...
Similar Threads for GrayScott Model
Mathematica FeynArts model file
Converting Simulink model to C code, integration
