Green function question
  • Thread starter WiFO215
I was reading up on Classical Mechanics and the general method for solving for an undamped harmonic oscillator was given as
[tex]\frac{d^{2}q}{dt^{2}} + \omega^{2}q = F(t)[/tex]
was solved using the Green function, G, to the equation
[tex]\frac{d^{2}G}{dt^{2}} + \omega^{2}q = \delta(t-t')[/tex]
and then integrating via the normal procedure.
Then the next case considered was the damped harmonic oscillator which had a damping term proportional to [tex]\frac{\omega}{Q}[/tex] times the velocity. The equation has the form
[tex]\frac{d^{2}q}{dt^{2}} + \frac{\omega}{Q}\frac{dq}{dt} + \omega^{2}q = F(t)[/tex]
Now, the author wants to find the particular solution to this equation and says that his Green function is of the form
G = [tex] A e^{\frac{{\omega(t-t')}}{2Q} + i\omega(t-t')}[/tex] plus this term's complex conjugate. This is a solution to STEADY STATE ONLY but does not consider the transient part.
BUT, he also claims that the above Green function is a solution the equation
[tex]\frac{d^{2}G}{dt^{2}} + \frac{\omega}{Q}\frac{dG}{dt} + \omega^{2}G = \delta(t-t')[/tex]
How can he do this? The Green function which will solve the above equation will also have a transient part apart from the steady state function which he has considered. G will be of the form above PLUS a dying out part. What happens to that?
Answers and Replies
Related Threads on Green function question
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
