Green's function
  • Thread starter rsq_a
This appears on the bottom of p.279 of this book.
The author begins with Green's second identity:
[tex]
\int_V \alpha \nabla^2 \beta - \beta \nabla^2 \alpha \ dV =
\int_C \left( \alpha \frac{\partial \beta}{\partial n} - \beta \frac{\partial \alpha}{\partial n} \right) \ ds[/tex]
Here, C is a closed curve, s is the arc length for C and n is the outward unit normal. We then let [itex]\alpha[/itex] satisfy Laplace's equation and let [itex]g = 1/(4\pi)\log [(x-x^*)^2 + (y-y^*)^2][/itex], i.e. the free-space Green's function. Then he gets
[tex]
\alpha(x^*, y^*) = r\int_C \left( \alpha \frac{\partial \beta}{\partial n} - \beta \frac{\partial \alpha}{\partial n} \right) \ ds,[/tex]
where r = 1 if (x*,y*) is inside C, but r = 1/2 if (x*, y*) is on C.
I'm confused at this point. I thought that
[tex]
\int_V \alpha \delta((x,y) - (x^*, y^*)) \ dV = \alpha(x^*, y^*)
[/tex]
Where is the factor of 1/2 or 1 coming in?
Moreover, the next equation, the factor of r = 1/2 has switched to the left-hand-side. I can't figure out how this is done (but perhaps if someone firsts helps me understand the above, this will be clear).
Answers and Replies
[tex]\alpha[/tex] is harmonic in V,but [tex]g[/tex] is harmonic in V except in [tex](x^*,y^*)[/tex],so (10.7)doesn't exist for [tex]g[/tex].
if [tex](x^*,y^*)[/tex] is inside C,we need to construct a ball [tex]B_\eplson[/tex] to cover [tex](x^*,y^*)[/tex],and the formula is wright for [tex]\int_{C \cup C_\varepsilon } {\left( {\alpha \frac{{\partial g}}{{\partial n}} - g\frac{{\partial \alpha }}{{\partial n}}} \right)} \;ds = 0[/tex],you can get the formula (10.8) from this.You need to do it yourself when the point is on C
[tex]C_\epsilon[/tex] is the boundry curve of B_\epsilon,you need to take limit for epsilon
Ah, I see. Can you verify that the formula (10.7) is indeed right, and the 'r' is supposed to be on the right-hand side?
I think it's supposed to be on the LHS. Then the 1/2 factor on the LHS of (10.9) would make sense.
I reason that for the case that (x*, y*) is inside C,
[tex]0 = \int_{C \cup C_\varepsilon } {\left( {\alpha \frac{{\partial g}}{{\partial n}} - g\frac{{\partial \alpha }}{{\partial n}}} \right)} \;ds = \int_{C} {\left( {\alpha \frac{{\partial g}}{{\partial n}} - g\frac{{\partial \alpha }}{{\partial n}}} \right)} \;ds -\alpha(x^*, y^*)[/tex]
because you end up with going around an entire circle for [itex]C_\epsilon[/itex], but if (x*, y*) is on the boundary, then
[tex]0 = \int_{C \cup C_\varepsilon } {\left( {\alpha \frac{{\partial g}}{{\partial n}} - g\frac{{\partial \alpha }}{{\partial n}}} \right)} \;ds = \int_{C} {\left( {\alpha \frac{{\partial g}}{{\partial n}} - g\frac{{\partial \alpha }}{{\partial n}}} \right)} \;ds - \frac{1}{2}\alpha(x^*, y^*)[/tex]
where the factor of 1/2 results from only going around half a circle.
I'm sorry I don't know how to derive (10.8) from (10.7),(10.7) is right,but my calculation don't get (10.8).
this is my calculation:
[tex]
\left. {\frac{{\partial g}}{{\partial n}}} \right|_{C_\varepsilon } = \left. { - \frac{1}{{2\pi r}}} \right|_{C_\varepsilon } = - \frac{1}{{2\pi \varepsilon }}[/tex],,,,,,,,,,,,,,,,,,,,,,,,,,,
[tex]\left. g \right|_{C_\varepsilon } = \frac{1}{{2\pi }}\ln \varepsilon[/tex],,,,,,,,,,,,,,,,,
so [tex]\int_{C_\varepsilon } {\left( {\alpha \frac{{\partial g}}{{\partial n}} - g\frac{{\partial \alpha }}{{\partial n}}} \right)} \:ds = - \frac{1}{{2\pi \varepsilon }}\int_{C_\varepsilon } \alpha \:ds - \frac{1}{{2\pi }}\ln \varepsilon \int_{C_\varepsilon } {\left( {\frac{{\partial \alpha }}{{\partial n}}} \right)} \:ds = - \int_C {\left( {\alpha \frac{{\partial g}}{{\partial n}} - g\frac{{\partial \alpha }}{{\partial n}}} \right)} \:ds[/tex],,,,,,,,,,,,,,,,,,,,,,
then [tex]
\frac{1}{{2\pi \varepsilon }}\int_{C_\varepsilon } \alpha \:ds + \frac{1}{{2\pi }}\ln \varepsilon \int_{C_\varepsilon } {\left( {\frac{{\partial \alpha }}{{\partial n}}} \right)} \:ds = \int_C {\left( {\alpha \frac{{\partial g}}{{\partial n}} - g\frac{{\partial \alpha }}{{\partial n}}} \right)} \:ds[/tex],
but I don't know how to eliminate the second term,and I also don't know where does the r come from.
Sorry
[tex]
then [tex]
Sorry
The second term ends up being lower-order than the first as [itex]\epsilon \to 0[\itex] (you'll get epsilon*log(epsilon)). And thus we are left with
[tex]
\frac{1}{{2\pi \varepsilon }}\int_{C_\varepsilon } \alpha \:ds = \int_C {\left( {\alpha \frac{{\partial g}}{{\partial n}} - g\frac{{\partial \alpha }}{{\partial n}}} \right)} \:ds[/tex]
The LHS will either give you [itex]alpha[/itex] (not on the boundary) or [itex]\alpha/2[/itex] (on the boundary). I'm not sure how that gives you (10.7). As I said in my post above, I think the 'r' should be on the other side in the formula.
we can get this equation [tex]
\int_V {\alpha \nabla ^2 \beta } dV + \int_V {\frac{{\partial \alpha }}{{\partial x}}\frac{{\partial \beta }}{{\partial x}}} + \frac{{\partial \alpha }}{{\partial y}}\frac{{\partial \beta }}{{\partial y}}dV = \int_C {\left( {\alpha \frac{{\partial \beta }}{{\partial n}}} \right)} ds[/tex]by Green Theorem,the same one[tex]\int_V {\beta \nabla ^2 \alpha } dV + \int_V {\frac{{\partial \beta }}{{\partial x}}\frac{{\partial \alpha }}{{\partial x}}} + \frac{{\partial \beta }}{{\partial y}}\frac{{\partial \alpha }}{{\partial y}}dV = \int_C {\left( {\beta \frac{{\partial \alpha }}{{\partial n}}} \right)} ds[/tex],then you can ge (10.7) by subtracting the first one from the second one.
and the r is on the right side,not left.But I can't see clear of your last post,the formula can't be displayed well.
How can we eliminate the second term?when eplison tends to 0,ln(eplison) tend to be minus infinity......
Related Threads on Green's function
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
