• Support PF! Buy your school textbooks, materials and every day products Here!
Greens theorem
##\mathscr{C}## is an ellipse ##\frac{x^2}{a^2} + \frac{y^2}{b^2} = 1##
and ##\vec{F}(x,y) = <xy^2, yx^2>##
write ##\displaystyle \int_\mathscr{C} \vec{F} \cdot d\vec{s}## as a double integral using greens theorem and evaluate
##\displaystyle \int_\mathscr{C} (Pdx+Qdy) = \iint_\mathscr{C} \Bigg(\frac{\partial Q}{\partial x} - \frac{\partial P}{\partial y}\Bigg)dA##
seems to be I need to use ##\nabla \times \vec{F} = \Bigg(0,0, \frac{\partial F_{2}}{\partial x} - \frac{\partial F_{1}}{\partial y}\Bigg) = (2xy-2yx)=0##
not sure about the double integral though, figured maybe this
##\displaystyle \int_{-a}^{a} \int_{-\sqrt{1-\frac{x^2}{a^2}-b^2}}^{\sqrt{1-\frac{x^2}{a^2}-b^2}}0dydx=0##
Answers and Replies
Orodruin
Staff Emeritus
Insights Author
6,239
Your problem is two-dimensional so the double integral should be over the interior of the ellipse.
If you necessarily want to see it as a 3D problem and apply Stoke's theorem, then the surface can be any surface with the ellipse as its boundary.
this was close to an example in my book, so where is it incorrect?
the book showed taking curl F then integrating over the boundary of the region in the given problem.
I don't know Stoke's theorem yet so I'd rather not try to apply that to this
Orodruin
Staff Emeritus
Insights Author
6,239
You need to rethink your limits for the y-integral, but they do not really matter since the integrand is zero.
Stoke's theorem (in the simple classical form) relates the integral of the curl of a vector field over a surface with the line integral of the same field along the border of that surface.
ah okay thanks, ##-b \le y \le b## in similar fashion to how x was treated?
vela
Staff Emeritus
Education Advisor
14,536
1,149
No, you need to check your algebra when you solved for ##y##.
##y=\pm \frac{b\sqrt{a^2-x^2}}{a}##
##\displaystyle\int_{-a}^{a}\int_{-\frac{b\sqrt{a^2-x^2}}{a}}^{\frac{b\sqrt{a^2-x^2}}{a}} 0 dydx##
HallsofIvy
41,770
911
What is the integral of 0 over any region?
It would be zero
Zero.
HallsofIvy
41,770
911
Yes, so there was no reason to worry about the limits on the integral to begin with. That was what Orodruin meant when he said "they do not really matter since the integrand is zero".
Related Threads for: Greens theorem
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
