How Do You Calculate Group and Phase Velocities for a 550nm Wavelength?
In summary, the conversation discusses finding the group and phase velocities for a given wavelength using a tab and the equations v(phase)= c/n and v(phase)*v(group)=c²/n². However, it is mentioned that these equations may not be applicable and the suggestion of using interpolation is given.
Dassinia
144
Hello
I have this tab
http://img18.imageshack.us/img18/3317/eyph.png
Anf I have to find the group and phase velocities for a wavelength λ=550nm
v(phase)= c/n
v(group)=dw/dk
I don't know how I can determine n for the wavelength of 550nm using the tab ?
I was absent the day of this course
Can I use the relation v(phase)*v(group)=c²/n² ?
Thanks !
Dassinia said:
v(phase)= c/n
Where do those two formulas come from? Where are they valid? Can you use them here?
Do an interpolation.
Interpolation is a much more general concept you should know.
The formulas come from my book, for electromagnetic waves.
Why can't I use them ?
OK, so I'll do an interpolation !
Thanks
Those equations would give v(phase)=v(group) everywhere, which is not true.
Please check how they got defined, and where they are applicable.
Dear student,
Thank you for your question. Group and phase velocities are important concepts in the study of wave propagation. Group velocity refers to the speed at which the "envelope" or "group" of a wave packet travels, while phase velocity refers to the speed at which the individual wave crests travel. In other words, group velocity describes the overall propagation of a wave, while phase velocity describes the propagation of the individual components of the wave.
To determine the group and phase velocities for a given wavelength of 550nm, we can use the tab provided. The tab shows the refractive index (n) for different wavelengths (λ) in a medium. The refractive index is a measure of how much a wave is slowed down when traveling through a medium compared to its speed in a vacuum. We can use the equation v(phase)= c/n to calculate the phase velocity, where c is the speed of light in a vacuum (3x10^8 m/s). In this case, n for a wavelength of 550nm would be 1.5 (from the tab). Therefore, the phase velocity would be 2x10^8 m/s.
To calculate the group velocity, we can use the equation v(group)=dw/dk, where w is the angular frequency and k is the wave number. The angular frequency can be calculated using the equation w=2πf, where f is the frequency. The frequency can be calculated using the equation f=c/λ. Therefore, w=2πc/λ. The wave number can be calculated using the equation k=2π/λ. Therefore, v(group)=dw/dk= (2πc/λ)/(2π/λ)= c. This means that the group velocity is equal to the speed of light in a vacuum, which makes sense since the group velocity represents the overall propagation of the wave.
Alternatively, you can also use the relation v(phase)*v(group)=c²/n² to calculate the group velocity. Using the values we calculated before, we get v(group)= c²/(n*v(phase))= (3x10^8 m/s)²/(1.5*2x10^8 m/s)= 2x10^8 m/s. This matches the value we calculated using the previous method.
I hope this helps clarify the concepts of group and phase velocities for you. If you have any further questions, please do not hesitate to ask. Good luck
1. What is the difference between group and phase velocities?
Group velocity refers to the speed at which the envelope of a wave packet moves, while phase velocity refers to the speed at which the individual wave crests move. In other words, group velocity describes the movement of energy, while phase velocity describes the movement of the wave itself.
2. How are group and phase velocities related?
Group and phase velocities are related by the dispersion relation, which is a mathematical equation that describes the relationship between the frequency and wavelength of a wave. The dispersion relation varies depending on the type of wave and the medium it is traveling through.
3. What is the significance of group and phase velocities?
The group and phase velocities of a wave are important because they help us understand how waves behave in different media. They also play a crucial role in the fields of optics, acoustics, and quantum mechanics.
4. Can group and phase velocities be different?
Yes, group and phase velocities can be different in certain situations. This is known as anomalous dispersion, where the phase velocity is greater than the group velocity. This can occur when a wave travels through a medium with a non-linear relationship between frequency and wavelength.
5. How do group and phase velocities affect wave propagation?
Group and phase velocities can affect wave propagation in various ways. For example, in the case of wave packets, the group velocity determines the overall speed at which the wave packet moves, while the phase velocity determines the speed at which the individual waves within the packet move. This can result in phenomena such as wave interference and dispersion. Additionally, the ratio of group to phase velocity can determine the shape and behavior of a wave as it travels through a medium.
  • Quantum Interpretations and Foundations
