Is a Group Homomorphic under Multiplication if it is Not Under Addition?
  • Thread starter Turnyface
  • Tags
    Group
In summary, the answer to the original question is that θ: Z->Z is a mapping where θ(n) = n^3 and it's homomorphism under multiplication. However, this is not a homomorphism under addition because for some value of n, m theta(n+m) is not equal to theta(n)+theta(m).
Turnyface
Consider θ:Z -> Z is a mapping where θ(n) = n^3 and it's homomorphism under multiplication. In this case, it's not a homomorphism under addition.
So my question is this. In general, if we show that a group is homomorphic under multiplication, does this imply that it is not under addition and vice versa?
What about the identity mapping?
Note, also, that the integers aren't a group under multiplication.
So if we take n=0 under addition, then it is a homomorphism, no? But for θ(n) = n^3 for elements not equal to 0, this is false. Does the operation have to be preserved for all n in order to be a homomorphism?
Edit: It has to be for all elements in Z. So it's not under addition, even considering the identity.
And to answer my own question:
Z->Z, θ(n)= n so θ(n+m) = θ(n)+θ(n)
Z->Z, θ(n)= n so θ(n*m) = θ(n)*θ(m)
Thus, the answer is no.
I'm not sure what you mean by this.
Regarding the OP, again, the integers are not a group under multiplication, so it makes no sense to talk about group homomorphisms here.
Can you recite the definition of homomorphism?
Let H be a subgroup of G. Let * be an operation under G and # be an operation under H. Then for all a,b in G:
θ(a*b)=θ(a)#θ(b)
is a homomorphism.
As number 9 says, we don't have a group here, so we cannot talk about group morphisms. However, [itex]\mathbb{Z}[/itex] does form a semigroup under multiplication so we can talk about semigroup morphisms.
For that, we just need to check the same thing, namely that
[tex]\theta(n*m)=\theta(n)*\theta(m)[/tex]
is this satisfied?
So back to the original problem where θ(n) = n^3.
So if n=0 and the homomorphism theorem above.
θ(m+n) = θ(0+0) = (0+0)^3 = 0^3 + 0^3, since 0=0. This is not true for any other elements in Z.
For the same mapping, θ(n) = n^3, θ(mn) = (mn)^3 = (m)^3 * (n)^3. So this is a homomorphism under multiplication.
is this satisfied?
The original question is this:
"Let θ: Z->Z. Let θ(n) = n^3. Is this a homomorphism under addition?"
For the answer to the question, I showed that with θ: Z->Z and θ(n) = n^3, this is a homomorphism is under multiplication.
Is this not correct?
No, it is not correct. The question is asking about addition. So its behavior under multiplication is not relevant. You just need to show that for some value of n,m
Figured. Hopefully partial credit is dished out.
I hate abstract algebra.
Thanks for the responses.
1. What is a group homomorphism?
A group homomorphism is a function that preserves the algebraic structure of a group. This means that the operation between two elements in the domain of the function will result in the same operation between their images in the range of the function. In other words, the function "preserves" the group structure.
2. How is a group homomorphism different from a group isomorphism?
A group homomorphism does not necessarily have to be a one-to-one and onto mapping, unlike a group isomorphism. This means that a group homomorphism can have elements in the domain that map to the same element in the range, while a group isomorphism must have a unique mapping for each element in the domain.
3. What is the importance of group homomorphisms in mathematics?
Group homomorphisms play a crucial role in abstract algebra, as they allow us to study the properties of groups by looking at their structures and relationships with other groups. They also have applications in other areas of mathematics, such as topology and number theory.
4. How do you determine if a function is a group homomorphism?
To determine if a function is a group homomorphism, you need to check if it preserves the group operation. This means that for any two elements a and b in the domain of the function, the function must satisfy the property f(a*b) = f(a)*f(b). If this property holds true, then the function is a group homomorphism.
5. Can a group homomorphism be surjective but not injective?
Yes, a group homomorphism can be surjective (onto) but not injective (one-to-one). This means that there can be elements in the domain of the function that map to the same element in the range, but there are no elements in the range that do not have a corresponding element in the domain. In other words, the function may not be a one-to-one mapping, but it covers the entire range of the group.
  • Linear and Abstract Algebra
