Homework Help: Group theory question
  1. Nov 14, 2007 #1
    If p is a prime and G is group of order p^2, then show that G is abelian.
    2. Relevant equations
    n/a
    3. The attempt at a solution
    I first consider Z(G), the centre of G. Since it is a normal subgroup of G, then by Lagrange's Theorem, |Z(G)| divides |G|. Hence |Z(G)| = 1, p or p^2. We know that Z(G) not the trivial subgroup (proof already given) hence it must be of order p^2 or p.
    If |Z(G)| = p^2, then Z(G) = G and hence by definition it is abelian.
    If |Z(G)| = p, then .... well this is where I am stuck! :(
    Please help!
  3. Nov 14, 2007 #2
    Dick
    Consider an element q that is not in Z(G). How big is the subgroup generated by q and Z(G)?
  4. Nov 14, 2007 #3
    In the case of your argument, if [itex] |Z(G)| = p [/itex] then we have that
    [itex]\frac{|G|}{|Z(G)|} = p[/itex] which we can't have.
    So on the other hand, we know that if [itex] \exists a \in G[/itex] such that [itex] o(a) = p^2[/itex] where [itex] o(a) [/itex] is the order of a, then [itex] G = C_{p^2} [/itex]. Thus we can assume that every non-identity element has order p, since the order of the elements must divide the order of the group.
    Thus consider a non-identity element of G, say a, and the subgroup it generates. Furthemore, consider another non-identity element, say b, that is not in [itex]<a>[/itex]. Such an element is guaranteed to exist since [itex]o(a) = p \Rightarrow |<a>|\neq|G| [/itex]. Consider the subgroup generated by [itex]b[/itex].
    What can we say about the order of [itex] <a> [/itex] and the order of [itex] <b> [/itex] ?. What can we say about their intersection? What can we say about the order of their product?
  5. Nov 14, 2007 #4
    If we assume that every non-identity element has order p, then <a>, <b> would have order p also. Wouldn't their intersection be the empty set if b is defined as an element not in <a>? Sorry I'm not sure where I'm supposed to go with this.
  6. Nov 14, 2007 #5
    That's precisely correct. They're intersection is empty, and so
    [tex] |<a> \times <b>| = \frac{|<a>||<b>|}{|<a>\cap<b>|} = |<a>||<b>| = p^2 [/tex]
    Thus, since [itex] a \in G, \; b\in G, \; \text{ and } |<a> \times <b>|=|G| [/itex] then
    [tex] <a> \times <b> = G [/tex]
    Now the question is, what is [itex] <a> \times <b> [/itex] isomorphic to?
  7. Nov 14, 2007 #6
    for any group G, if G/Z(G) has prime order, then G/Z(G) is cyclic, hence G is abelian
  8. Nov 14, 2007 #7
    Cyclic group of order p^2?
  9. Nov 14, 2007 #8
    JasonRox
    Assume G is non-abelian and go by contradiction.
    And you'll need ircdan's statement.
    It's a nice question.
  10. Nov 14, 2007 #9
    [tex] C_p \times C_p [/tex]
  11. Nov 14, 2007 #10
    Via this method we've actually proved something stronger than the actual question. Namely that every group of order [tex] p^2 [/tex] is isomorphic to either [itex]C_{p^2} \text{ or } C_p \times C_p [/itex]
  12. Nov 14, 2007 #11
    JasonRox
    This question pretty much does that.
  13. Nov 14, 2007 #12
    Is [tex]C_p \times C_p[/tex] also cyclic? How do you know it is abelian?
  14. Nov 14, 2007 #13
    C_p x C_p is not cyclic but it is abelian since each factor is
  15. Nov 14, 2007 #14
    JasonRox
    This question tells us that all groups of order p^2 are abelian.
    What kind of abelian groups are there of order p^2?
    Well, it can be cyclic if it has an element of order p^2 if not, then all the elements must be of order p (Lagrange's Theorem). And you work from there.
  16. Nov 14, 2007 #15
    Thanks for all the help! I've written the proof both ways and they seem to be pretty much equivalent.
    I'm not sure if I should open a new thread for this but I would appreciate some help on another related question:
    "If G is a group of order 48 then show that it is not simple"
    Now |G| = 2^4 * 3. I'm thinking it would be a similiar argument to how you show groups of order (p^2 * q) are not simple, but in all honesty I don't even understand the proof for that very well.
    I guess if you apply Sylow's theorem, then clearly there are Sylow p-subgroups of order 2^4. Are these p-subgroups normal? If so, how would you go about showing this?
  17. Nov 14, 2007 #16
    A theorem by Burnside states that the center of a finite p-group is non-trivial. So if |G|=p^2 and Z(G)!=G choose x in G so that x not in Z(G). We know by divisibility that Z(G) >= p (Burnside). But that means the centralizer C(x) must be G a contradiction. So Z(G)=G.
  18. Nov 15, 2007 #17
    you can produce a counting arguement
  19. Nov 15, 2007 #18
    Can you elaborate on that? (I assume you are talking about |G| = 48 not being simple)
  20. Nov 15, 2007 #19
    I imagine you should exploit the class equation
  21. Nov 15, 2007 #20
    morphism
    How many of these can we have? Let n be the number of Sylow-2's. Then n=1(mod2) and n|3. This leaves us with n=1 or n=3. If n=1, we're done, because this implies the unique Sylow-2 is normal in G (why?). So suppose n=3. One possible way you can proceed from here is via group actions. Let G act on the set X of 3 Sylow-2's by conjugation. This induces a nontrivial homomorphism from G into Sym(X). What is its kernel? (Don't think too hard about what the kernel actually is; think about what kernels are, and how they could be relevant to proving the non-simplicity of G.)
