Finding Centraliser of (12)(34) in S_4
  • Thread starter latentcorpse
In summary: The elements of cycle type (2,2) are both in the conjugacy class and in the centraliser because they are conjugate to (12)(34), and conjugation preserves the cycle type of a permutation. In summary, the centraliser of (12)(34) in S_4 has size 8 and consists of (12)(34), (13)(24), (14)(23), (12)(43), (13)(42), (14)(32), (23)(41), and (24)(31).
latentcorpse
1,444
What is the centraliser of (12)(34) in [itex]S_4[/itex]. check your answer is consistent with the size of the conjugacy class.
so i found the conjugacy class had size 3.
and hence by orbit stabiliser the centraliser must have size 8.
now under conjugacy action [itex]C(g)=\{g \in G | gh=hg\} = Stab(g)[/itex]
clearly (12)(34) is comjugate to the identity and the 2 other elements with cycle type (2,2) so that's me found 4 elements. according to the answers the other elements in the centraliser are two 4 cycles and 2 transpositions - but how can we tell which 4 cycles and which transpositions these are?
also, since elements of cycle type (2,2) are conjugate to (12)(34) and so these will be in the conjugacy class but according to the above they are also in the stabiliser/centraliser - why is this?
The centraliser of (12)(34) in S_4 is the set of all permutations that commute with (12)(34), i.e. those that leave it invariant under conjugation. These are: (12)(34), (13)(24), (14)(23), (12)(43), (13)(42), (14)(32), (23)(41), (24)(31). The size of the conjugacy class is 3, since (12)(34) is conjugate to itself and the other two elements of cycle type (2,2), which are (13)(24) and (14)(23). The stabiliser or centraliser of (12)(34) then has size 8, since by the Orbit-Stabiliser Theorem, the size of the centraliser is equal to the size of the conjugacy class multiplied by the size of the stabiliser. The four 4-cycles and two transpositions can be determined by noting that the 4-cycles are conjugates of (12)(34), and the transpositions are conjugates of the pairs of transpositions that form a 2-cycle in (12)(34).
1. What is the centralizer of (12)(34) in the symmetric group S_4?
The centralizer of (12)(34) in S_4 is the set of elements in S_4 that commute with (12)(34). In other words, it is the set of permutations that leave (12)(34) unchanged when composed with it.
2. How do you find the centralizer of (12)(34) in S_4?
To find the centralizer of (12)(34) in S_4, we can use the formula: C_G(x) = {g in G | gx = xg}, where C_G(x) is the centralizer of x in the group G. In this case, x = (12)(34) and G = S_4. We can also use the fact that the centralizer of (12)(34) is isomorphic to the permutation group on the elements that are fixed by (12)(34).
3. What is the order of the centralizer of (12)(34) in S_4?
The order of the centralizer of (12)(34) in S_4 can be determined using the orbit-stabilizer theorem, which states that the order of the centralizer of x in a group G is equal to the order of G divided by the size of the orbit of x. In this case, the orbit of (12)(34) in S_4 is {1, (12)(34)}, so the order of the centralizer is 24/2 = 12.
4. Can you provide an example of an element in the centralizer of (12)(34) in S_4?
One example of an element in the centralizer of (12)(34) in S_4 is (1234). This permutation commutes with (12)(34) because (1234)(12)(34) = (1342) = (12)(34)(1234).
5. How does finding the centralizer of (12)(34) in S_4 relate to group theory?
Finding the centralizer of (12)(34) in S_4 is an example of using group theory to study the symmetries of a set. In this case, the set is the set of permutations in S_4, and the centralizer allows us to identify the elements in S_4 that preserve the structure of (12)(34). This concept is important in understanding the structure of groups and their subgroups.
18K
9K
9K
  • Linear and Abstract Algebra
17K
