Solving for K and Time when P=44 in Alligator Population Problem
In summary, the conversation discusses a problem involving finding the constant K in a formula for the time rate of change of an alligator population in a swamp. The formula is dP/dT = KP^1/2 and the swamp currently has 9 alligators in 2000 and 25 alligators in 2005. The conversation suggests solving for C and K using the given information and setting up two equations.
Eng67
I am having a problem with finding the constant K in This problem.
The time rate of change of an alligator population P in a swamp is proportional to the square root of P. The swamp contains 9 alligators in 2000 and 25 alligators in 2005. When will there be 44 alligators in the swamp?
I have determined the formula dP/dT = KP^1/2
P(0)=9, P(5)=25
P^-1/2dP = Kdt and 2P^1/2=C + Kt
A simple push with how to introduce the values into this equation would be greatly appreciated.
If I'm not mistaken...
[tex]2\sqrt{p} = c + kt [/tex]
if t = 0, then p = 9, and the kt term disappears, so you can get a value for C. Then do the same kind of thing for the value of k using the other piece of data you are given.
Two unknowns, C and K, so you need two equations. You are given two pieces of information. As finchie_88 suggested (although he didn't say it explicitely), let t be the number of years since 2000. Then when t= 0, P= 9 and when t= 5, P= 25. Put those numbers into your formula to get two equations for C and K.
Thanks for the replies! It has become much clearer now.
1. How do you solve for K and time in the Alligator Population Problem when P=44?
To solve for K and time in the Alligator Population Problem when P=44, you can use the formula P=Pe^rt, where P is the final population, r is the growth rate, and t is the time. Plug in the given value of P=44 and solve for t. Then, use the formula K=P/e^rt to solve for K.
2. What is the significance of solving for K and time in the Alligator Population Problem?
Solving for K and time allows us to accurately predict the future population of alligators in a specific area. This information is crucial for conservation efforts, as well as for studying the impact of alligators on their ecosystem.
3. Can the Alligator Population Problem be solved using any other methods?
Yes, there are other methods for solving the Alligator Population Problem, such as using a graphing calculator or creating a table of values. However, the formula P=Pe^rt is the most efficient and accurate method.
4. Is solving for K and time in the Alligator Population Problem applicable to other species?
Yes, the formula P=Pe^rt can be used to solve for the population of any species as long as the growth rate is known. It is a common formula used in population dynamics and can be applied to various organisms.
5. How does the Alligator Population Problem relate to real-life situations?
The Alligator Population Problem is a simplified version of real-life population dynamics seen in alligator populations and other species. By studying this problem, scientists can gain a better understanding of how populations grow and change over time, which can be applied to real-life conservation and management efforts.
