Solve Guass' Law Q for Ey: Find Electric Field at Point P
The surface area of a sphere is 4*pi*r^2.The insulator is a spherical shell with inner radius a = 4 cm and outer radius b = 6 cm. So the center of the sphere would be at the center of the shell, and the radius of the sphere would be (b-a)/2 = 1 cm. Now, how much charge is enclosed within this sphere?The charge enclosed within the sphere would be the total charge Q = +9 μC. So now, using Gauss's Law, we can say that:integral(E.da) = Qenclosed/ε0Where ε0 is the permittivity of free space. Plugging in the values, we get:E *
k.ingleman
An insulator in the shape of a spherical shell is shown in cross-section at this site: http://kingleman.webs.com/apps/photos/photo?photoid=98095962 . The insulator is defined by an inner radius a = 4 cm and an outer radius b = 6 cm and carries a total charge of Q = + 9 μC (1 μC = 10-6 C). (You may assume that the charge is distributed uniformly throughout the volume of the insulator).
What is Ey, the y-component of the electric field at point P which is located at (x,y) = (0, -5 cm) as shown in the diagram?
Ey =
none
not sure how to get the solution..I know you need to use Guass' Law
You will also want to get the charge density. You'll want to use Gauss' Law, and some integration (though the integration is easy and not entirely necessary if you know areas and the principles of integration). Give it a try and let us know where you get caught up.
OK, well given that you know that, what do you know about Gauss's Law? Specifically, what's the equation? (It's not "none" :wink:)
I know that qenclosed = ρ*V and so i took qenclosed(9 *10^-6) divided by volume (4/3)*pi*(b^3 - a^3) and got p = .0141...I'm just not sure what to do next..Guass' Law is integral(E.da) = Qenclosed/8.85×10−12
Think about it like this: Gauss's law is an equation that describes an imaginary surface. It tells you something about the electric field on that surface, based on the charge enclosed inside the surface.
So the first thing you need to do is pick a surface. Which surface would it make sense to use for this problem?
I think you'd use a sphere
Yep, that's right. Now, what is the surface area of a sphere, and how much charge is enclosed within that sphere?
And which sphere? e.g. where is its center? How big is it?
1. What is Guass' Law?
Gauss' Law is a fundamental law in electromagnetism that relates the electric flux through a closed surface to the charge enclosed by that surface. It was developed by physicist Carl Friedrich Gauss in the 19th century.
2. How is Guass' Law used to find the electric field at a specific point?
To find the electric field at a point, we use Gauss' Law by first choosing a closed surface that contains the point of interest. Then, we calculate the electric flux through that surface and equate it to the enclosed charge divided by the permittivity of free space. This allows us to solve for the electric field at the point.
3. What is the equation for solving Guass' Law for the electric field at a point?
The equation is: E = Q/ε0 * A, where E is the electric field, Q is the enclosed charge, and ε0 is the permittivity of free space. A represents the area of the closed surface chosen to calculate the electric flux.
4. Can Guass' Law be used for any shape of a closed surface?
Yes, Gauss' Law is a general law that applies to any closed surface, regardless of its shape. However, it is easier to use for symmetric shapes such as spheres, cylinders, and planes.
5. How is the direction of the electric field determined using Guass' Law?
The direction of the electric field is determined by the direction of the electric flux through the closed surface. The direction of the electric flux is always perpendicular to the surface, so the electric field will also be perpendicular to the surface at the point of interest.
