Homework Help: Guass's Law over the x axis
  1. Feb 19, 2013 #1
    Charge is uniformly distributed along the x axis with density ß. Use Gauss' Law to find the electric field it produces, and use this to calculate the work done on a charge Q that moves along the y axis from y = a to y = b.
    2. Relevant equations
    [itex]\phi[/itex]=[itex]\int[/itex][itex]\vec{E}[/itex]*[itex]\hat{n}[/itex]dA
    [itex]\phi[/itex]= [itex]\frac{Q}{\epsilon}[/itex]
    3. The attempt at a solution
    I used a cylinder for my surface since the normal vector will always align with the electrical field. So the first part, the equation ends up
    [itex]\phi[/itex]=E[itex]\int[/itex]dA
    [itex]\phi[/itex]=E(2∏rh)
    (r is the radius from the axis to the edge of the cylinder and h is the length of the cylinder.)
    and if I remember right, Q is the density times the are of enclosure.
    so Q = β(2∏rh)
    I set the two [itex]\phi[/itex] equations equal to each other and get
    [itex]\frac{β}{ε}[/itex]=E
    I don't think that's right though. What did I do wrong?
  3. Feb 19, 2013 #2
    Since the charge is along the x-axis, then β is a linear charge density.
    So, to get the charge enclosed, you multiply β by the length h, and not the volume.
  4. Feb 19, 2013 #3
    tiny-tim
    Hi Colts! :smile:
    No, "density" here means the line density (in coulombs per metre, not per metre3)
    So Q = βh. :wink:
    (of course, sometimes "density" means surface density, and occasionally it actually means density! :rolleyes:)
    EDIT: ap123 beat me to it! :biggrin:
  5. Feb 19, 2013 #4
    So the electrical field is
    E = [itex]\frac{β}{2πrε}[/itex]
  6. Feb 19, 2013 #5
    Is the last question asking me to integrate E from a to b?
  7. Feb 19, 2013 #6
    SammyS
    Staff Emeritus
    Integrate the force, FExt, that would need to be exerted on a charge, Q, to move the charge from a to b . (Actually integrate the work the force does.)
  8. Feb 19, 2013 #7
    [itex]\int[/itex][itex]\frac{βxdx}{2πrε}[/itex]
    x is the distance
    does that look right? and the integral would be from a to b
  9. Feb 19, 2013 #8
    SammyS
    Staff Emeritus
    Not correct.
    What is the force on a charge Q located on the y-axis , a distance y from the x-axis ?
    You (or some outside agent) must apply what force on Q to move it, at a constant rate, when the charge is located on the y-axis ?
    Added in Edit:
    Another way to do this is to find the potential difference from y = a to y = b .
    To do that, you do integrate -E .
