Can a Hippie Out-Tool a Trucker in a Tyre Changing Contest?
  • Thread starter houlahound
In summary: I like to bring up these sorts of tools, because it's worth taking a minute to think about what we'd do in a world without string. No clothes other than leather, no string to make traps with, no sails to explore the seas, no baskets, no pottery, etc.
  • #36
houlahound said:
Looks too sciencey for this thread...no fair.
I'm calling a foul ball.
It's still a tool! If you look at the components, it's not too hard to work out the kind of thing it is.
  • #37
Likes e.bar.goum
  • #38
For??
  • #39
OCR said:
It's an alignment telescopes manufactured by Taylor Hobson.
Bingo. I guess that means its your turn to provide a tool!
  • #40
Hint, mostly worn as a waist belt.
No reverse engineering the images - new rule.
  • #41
houlahound said:
For??
The micro http://www.taylor-hobson.com/products/27/108.html#Micro-Alignment-Telescopes-with-built-in-optical-micrometers2 allows the user to set reference lines of sight for applications such as the alignment and measurement of bearings and bores.
  • #42
Gotcha, technically it's your go.
  • #43
  • #44
Your in the ball park as far equine related...and I meant human waist not horse waist in my hint.
  • #45
Must be a Surcingle Belt, then...?
  • #46
Nope...getting colder.
Hint 2. Its mostly worn around a human waist but when its not it is worn on a horse but not around the horse's waist.
  • #47
Lol... I don't know, unless it's some part of a safety harness ... :blushing:
  • #48
Likes OCR
  • #49
Part of the belly band on a draught horse harness ?
  • #50
They are temporary/short duration hobbles to restrict a horses mobility while the rider is dismounted and wants his horse to graze and not get spooked and run off.
Usually while the rider is taking a break.
Likes OCR
  • #51
houlahound said:
Looks like hobbles, to me...?
  • #52
Correct, see above post.
Well done, I'm out for a while.
  • #53
Ah, the rider more or less stores the hobbles as a belt around his waist, and takes it off to use as hobbles...?
  • #54
I will have a go. I had to blur out what is cast into the tool as I am afraid it would give it away.
  • #55
Some kind of toe jack?
  • #56
Well I don't think it would be a risk of giving it away if I say that it is in fact meant to move two items apart as a jack of course would. However, this device was engineered for a specific purpose and from experience I will say that it does it quite well. Its intended purpose was not to lift things.
  • #57
Pinch bar used for moving railway locomotives and trucks short distances during maintenance ?
  • #58
Nope. I will give another clue. I am sure someone on this forum has done the task that this tool is meant to do, only done it the hard way. I will tag my favorite member again. LOL. @jim hardy The tool in the very first image in this thread has likely been used many times to do what this tool is designed for. Not as a chopping operation though.
  • #59
Ahhh!...
...it is in fact meant to move two items apart...
I am sure someone on this forum has done the task that this tool is meant to do...
It's a bead breaker! ?
  • #60
http://www.dlokka.hommboi.lokka.com/img/photos/1244962657-Beadcheater2.jpg​
  • #61
Ding ding ding! We have the correct answer.
Bead buster is actually cast into the tool so I had to blur it out.
Likes OCR
  • #62
Lol...[COLOR=#black]..[/COLOR] :ok:
  • #63
would never have got that one.
Likes OCR
  • #64
What gave it away @OCR ?
  • #65
What gave it away
The pinched fingers, skinned knuckles, ...
Likes OCR
  • #66
real men don't use a gadget to break the bead.
you either use two tyre levers or put the tyre flat on the ground and run over it with another vehicle a few times.
= real men would never have seen such a device...disqualified.
Likes OCR
  • #68
good point.
Likes OCR
  • #69
I've used a device like that on big tractor tires, where you don't remove the rim from the tractor... just the tire off the rim.
The breaker I used was powered by air, so your picture wasn't a dead give away... the design of the "foot" in the upper right, picture two helped, so did your clues...
I googled "bead breaker", and found the image I posted...
Tires I used the tool on...
  • #70
Try that with these:
Lol... yup, they're 30.5-32 radials... :oldsmile:
  • General Discussion
