null void
- 102
- 1
calculate current and voltage amplification
Conversion to h parameter model,
and this is my working step,
https://www.filesanywhere.com/fs/v.aspx?v=8b6b628b5e646faf6e9b
null void said:there are something i can't understand, in my calculation, i use equation 3 to find Ai, i get -132... But if i use equation 6 instead of 3, i get 132..., same number but different sign. I suppose there is something went wrong in my equation 6...
Also, I don't see anywhere where you have taken Rs into account. Rs has a very large effect on Av.
I would think that Av would be defined as Vout/Vs. Is your problem defining it as Vout/Vin, which is the same as Vout/Vb?
A further suggestion: I think it's a good idea to informatively label dimensionless parameters, e.g.,
hfe = ... amps/amp
hre = ... volts/volt
null void said:...i can't really figure out how to include the Rs in the calculation
Oh yeah, I get what u mean.You may need a sign change. The arrow direction for iout is indicating iout = - vout / RC
An easy way is to calculate the input resistance at the Vin node, and use that impedance plus the 1k Rs to form a voltage divider. The voltage division ratio from the Vs node to the Vin node can be multiplied times the Av you already calculated to get the overall voltage gain from Vs to Vout.
null void said:I find it is a bit tricky to find the input impedance even tough Rs is not included because of the HreVout, it causes great pain for me to kill off Ib , Iin and Vb.
NascentOxygen said:You may need a sign change. The arrow direction for iout is indicating iout = - vout / RC
The "H parameter model" is a mathematical model used in scientific research to describe and analyze the behavior of complex systems. It was developed by physicist Hermann Haken and is based on the principles of self-organization and non-equilibrium thermodynamics.
Unlike other mathematical models, the "H parameter model" takes into account the interactions and feedback between different components of a system, rather than treating them as isolated entities. This allows for a more comprehensive understanding of complex systems, particularly in the fields of biology, chemistry, and physics.
The "H parameter model" has been used to study a wide range of phenomena, including chemical reactions, neural networks, and ecological systems. It has also been applied in fields such as economics, sociology, and engineering to better understand and predict the behavior of complex systems.
While the "H parameter model" has proven to be a useful tool in studying complex systems, it also has its limitations. It is a highly theoretical model and may not always accurately reflect real-world systems. Additionally, it requires a significant amount of computational power and data to accurately simulate and analyze complex systems.
The "H parameter model" can provide scientists with a more holistic understanding of complex systems and their behavior. It can also help identify patterns and relationships within these systems, leading to new insights and discoveries. Additionally, the model can aid in predicting the behavior of complex systems under different conditions, allowing for more informed decision-making in various fields of study.
